removeing reflectors
Old Mar 16, 2014 | 07:44 PM
128auto's Avatar
128auto
Ppl always recommend floss and fishing lines. Trust me, the most effective way is hair dryer. Heat it up to the right temp and wiggle, that's it!
Old Mar 16, 2014 | 08:11 PM
case013's Avatar
case013
Just removed all mine a few days ago with fishing line and goo gone. Do not saw the fishing line. Just soak reflector for a couple minutes in goo gone then give the fishing line a good coat and pull. Pulled all four of mine in about 15min including clean up time.
Old Mar 16, 2014 | 10:05 PM
dublenut's Avatar
dublenut
I used the fishing line and goo gone also. Worked good
Old Mar 17, 2014 | 02:21 AM
ShiftyCapone's Avatar
ShiftyCapone
Originally Posted by Silvio
If you're talking about the one that's attached up under the rear of the fender, I just manhandled it loose on my Street Bob.
Nothing up under there to worry about looking pretty, and the adhesive will peel off with a little force and twisting.
Everything else was GOO Gone and fishing line...
Old Mar 17, 2014 | 02:33 AM
bad93snake's Avatar
bad93snake
Gotta do this tomorrow, going combo fishing line/goo gone method.
Old Mar 17, 2014 | 05:52 AM
dwebber's Avatar
dwebber
wife's hair dryer worked like a charm, cleaned up with WD-40
Old Mar 17, 2014 | 06:11 AM
land of giants's Avatar
land of giants
Why would you want to reduce the ability to be seen by the cage drivers?
Yes, I get it - the clean look, make it your own etc. T-boned by a Buick or a little red reflector on you bike - Hmmmm?
Old Mar 17, 2014 | 06:41 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Warm up the area with a hairdryer and then dental floss or lite fishing line and then some goo gone.
Old Mar 17, 2014 | 08:42 AM
coastie743's Avatar
coastie743
Just my take on it, but pretty sure if they dont notice me and the motorcycle, its probably due to the fact they arent paying attention, not the visibility aspect. I doubt a reflector will make them look up from texting, or the radio, or whatever else has their attention. I can not imagine a reflector being a causitive factor in any accident. Maybe for a runner or someone on a bicycle with no other lights, but on a motorcycle, hardly...
Old Mar 17, 2014 | 10:03 AM
WhereduGo?'s Avatar
WhereduGo?
Squirt the backside of the adhesive with wd 40 let it soak in for 5 min then grab it and twist it.
