Smaller grips
Old Apr 7, 2014 | 03:54 PM
shiftace's Avatar
shiftace
Originally Posted by kreeess
which model biltwells do u have? they look good and the price is definitely easy in the pockets!
Kung Fu's. You can cut your old grip off your throttle sleeve and slide these right on. No need to get a new sleeve. I always cut some length off the ends of any bars I run, so I usually wind up cutting a little off the grip too.
Old Apr 7, 2014 | 04:31 PM
kreeess's Avatar
kreeess
Originally Posted by SLV
I've ran Biltwell, Avon Old School, Baxter, and these Motogrips http://motogrip.net/motogrip/#/motogrip/?page_id=228
They're all pretty good. The Biltwell Kung-Fu grips are my least favorite, but only because they get very sticky in the hot sun. The Baxters, in my opinion, are the best of the MX style because the material is hard enough to not twist or flex.
My favorite from all four are the Motogrips. They are made of a silicone gel material that is soft to the touch, but provide a great grip with or without gloves.
Keep in mind though, the Baxter, Biltwell and Motogrips do not have built-in throttles. You'll need a throttle tube to make them work. Biltwell makes one called the Whiskey Throttle Tube that works great.
The Avon Old School and Jack Hammer grips are nice because they have the throttle tube built-in.
This is the Whiskey Throttle Tube. Other people make them too.
thanks for the info! I wouldnt have known that these grips actually needed separate throttle sleeve, really like the bobber look so im def going for some colored grips
im interested in this technique, do you have pics of ur grips? Ive heard people cutting the old grips and swapping it out but wasnt too sure if that was good or bad...
Old Apr 8, 2014 | 12:10 PM
y22c's Avatar
y22c
Originally Posted by Nomadmax
Sportster grips, 04 and on. Much smaller, I run them on my 02 Dyna. And they're cheap.
+1
Ken
Old Apr 8, 2014 | 05:12 PM
kreeess's Avatar
kreeess
Originally Posted by y22c
+1
Ken
do I need to modify anything to make the sporty grips work on a dyna?
Old Apr 8, 2014 | 05:20 PM
shiftace's Avatar
shiftace
Don't have a pic of mine, sorry. But depending on what kind of grips you have now, removing them is usually pretty easy. a lot of times I used compressed air to blow them off, pry up the edge a little and wedge the nozzle underneath. A few quick blasts and they'll start to loosen up and slide off. Other times I've had to use a cut off wheel (veeery carefully) cut em lengthwise and break em off. If yours are rubber already, use a razor and slice em up. No changes necessary for using sporty grips on dynas, remove and replace.
Old Apr 8, 2014 | 10:48 PM
kreeess's Avatar
kreeess
I have stock grips right now(2014 FXDB) I don't care for the stock grips and I'm really liking the old school look, looking in to getting the white Kung fu or something similar, any suggestions?
Old Apr 10, 2014 | 08:40 PM
gant's Avatar
gant
hit me up man i got some slip ons in my garage for you lol
Old Apr 11, 2014 | 11:06 AM
y22c's Avatar
y22c
Nope.
Ken
Old Apr 11, 2014 | 02:56 PM
Sharkman73's Avatar
Sharkman73
Consider a set of grips from a '14 Low Rider...they are smaller diameter grips than the rest of the Dynas.
Old Apr 11, 2014 | 03:14 PM
Guest
Guest
Posts: n/a
My girlfriend loves my kung-fu grip, just sayin. lol
