Mirror Vibration while Riding
Old Apr 8, 2014 | 09:13 PM
STREET BOB JOE's Avatar
STREET BOB JOE
Default Mirror Vibration while Riding
So since putting on my t-bars with poly bushings my mirrors are pretty useless cause they vibrate so bad I can't see sh*t. Any simple solutions or is that just the way its gonna be now? Not the end of the world but didn't know if there was a little trick or fix.
Old Apr 8, 2014 | 09:21 PM
Unit 91's Avatar
Unit 91
Mine vibrate quite a bit. Quick goose of the throttle when I want to really see behind me and solved.
Doubt that helps, but it's how I deal with it.
Old Apr 8, 2014 | 09:24 PM
maddghost's Avatar
maddghost
Just have to deal like the rest of us I guess, sorry but it's the truth.
Old Apr 8, 2014 | 09:37 PM
STREET BOB JOE
That's cool just wanted to check with some other peeps
Old Apr 8, 2014 | 10:23 PM
monster715's Avatar
monster715
You could try the vibra technics front motor mount, a lot of guys say they can see out of their mirrors better after the install. I put one on and can notice a difference in the grips but I still can't see out of my mirrors very well either. One of the downsides to a solid bar setup. If your going faster then everyone else you don't need the mirrors Chances are the boys already nailed you on your speed by the time they're behind you
Old Apr 8, 2014 | 10:30 PM
b2inUT's Avatar
b2inUT
Same with me. I've got a 2012 street bob with the integrated clamps on the riser--no bushing of any sort. Bars are stuff as ****.
Old Apr 9, 2014 | 01:35 AM
atco's Avatar
atco
Hi, I banged some 18 oz lead sinkers to my bar ends, vibes gone for the most. Works as a bar end weight but heavier and more effective. Cheap mod.
Old Apr 9, 2014 | 04:06 AM
Prodriverdon's Avatar
Prodriverdon
Had same problem,went to shorter stems and it was fixed.
Old Apr 9, 2014 | 09:53 AM
mattVA's Avatar
mattVA
Mirrors on mine were useless above 2500 RPM. .drag bars, if that matters. Swapped motor mounts to Vibra-Technics and I can see clearly now, slight buzz, but I can make out the vehicle behind me at any RPM. I had tried everything you can think of before and nothing fixed.
Old Apr 9, 2014 | 10:04 AM
jcallesano's Avatar
jcallesano
I switched my hand controls and risers and made the switch from rubber bushings to poly bushings. The rubber ones are none sense.
