Screamin' Eagle Stage 1 kits
Old Mar 26, 2007 | 01:15 PM
Lucky MN HD's Avatar
Lucky MN HD
Stage III
Default Screamin' Eagle Stage 1 kits
Hope someone can help. I have a 2001 FXDWG with a stage 1 kit on it and after driving awhile it blows a little oil out. What can I do? Your thoughts and help would be greatly appreciated.[]
Old Mar 26, 2007 | 01:39 PM
thrillseeker's Avatar
thrillseeker
Default RE: Screamin' Eagle Stage 1 kits
is the stage 1 kit pre 2005? (I don't want to assume based on your bike year).
If its the new design, which came out either late 2004 or early 2005, and you are getting oil... I might suggest making sure you aren't putting too much oil in yourbike.
If its from 2001 - this is a pretty common problem. Use Google and search "harley + oil puking" (without the quotes, but with the +). There might be some help here as well. This topic used to come up all the time a couple years ago, but I never really paid attention cuz I never had the problem (I have the newer SE intake).
Old Mar 26, 2007 | 01:57 PM
Lucky MN HD
Stage III
Not sure what year kit it is I bought the bike with it. Only owned the bike 1 1/2. thanks for the suggestion though
Old Mar 26, 2007 | 03:05 PM
thrillseeker
my guess would be its the older design. I don't know how to fix the problem, but there are a ton of discussions about this, across numerous HD discussion boards. You might find someone here that knows the fix.
I suspect this thread will get moved to a tech section since it isn't Dyna specific. You will probably get more people looking at it once that happens.
Old Mar 28, 2007 | 01:13 AM
bobby5's Avatar
bobby5
sounds like you forgot to put the black O ring in
YeaThatsMe
Mar 26, 2017 05:23 PM
JoeN
May 5, 2015 06:22 PM
2012RKclassic
Jul 24, 2012 01:53 PM
primeaus883
May 26, 2008 02:32 PM
BAW
19
Sep 21, 2006 10:06 PM
