New member with an 'old' problem
Old Apr 14, 2014 | 04:33 PM
dirtdobber's Avatar
dirtdobber
From what I have read it is a battery issue.
Questions:
Was the compression raised to What?
No compression releases, can result in a damaged starter. Without cr it is really hard on a battery and it can cause starter damage. The head light should go out when cranking or at least get dim because of the extra current draw. Try a 140 amp battery. My 113 won't turn over unless the CR's are open
Also if the battery was ever drained completely it may not be up to par for it to crank the bike.
With the light fuse pulled how does it turn over? good or fair.
Old Apr 15, 2014 | 02:02 AM
PTSDBob's Avatar
PTSDBob
I am just on the 'outside looking in' but would an LED headlight make any difference on the bat draw ?
Old Apr 15, 2014 | 08:10 AM
Brettfullthrottle's Avatar
Brettfullthrottle
Originally Posted by rooti
The bikes pissed off at you for not riding her.
I would start with the battery cables. Take them apart on both ends, clean them up, and retighten them. Also go through every fuse and clean and put deelectric grease on them.
I doubt very much it is the starter...if it still gives you problems try replacing the starter relays. I have a feeling there is some corrosion somewhere.
Once you fix it, ride it...move it or lose it. Dyna's can't stand sitting in one place for too long
I have to agree. Harleys need to be ridden. She needs more attention. She feels neglected.
Old Apr 15, 2014 | 08:29 AM
snatchcat's Avatar
snatchcat
Hey bud, think maybe you answered your own question in your last sentence. because I also think a new starter/solenoid would be in order.... another guess would be that there's a internal short (maybe intermittent) happening somewhere in that starter that's killing those batteries. just a machinist (mostly mechanical minded) here so take my comments with a grain of salt eh!
Whiskyjock
Nov 15, 2017 10:24 AM
Kevin714
Nov 19, 2016 07:45 PM
elecwiz1
Electrical/Lighting/Alarm
11
May 30, 2015 10:17 AM
Vic Bronco
Sep 21, 2013 12:07 AM
Tanker2
Apr 23, 2008 02:17 PM
