120r Fat Bob (A must read)
Old Apr 16, 2014 | 08:10 PM
mademoney101's Avatar
mademoney101
6th Gear
Default mods
I got the 120R for $4,500. It was a pretty good deal at the time, I'm running a 58mm throttle body figured it would help keep the Torque up on it in the low RPMs. As fare as 300 cfm I will post them soon and the heads are done.They are being check every thousand @ 28 inchs . If there are some flow numbers that you fellows want to post I know, I would like to see them.Look up Dean Gillner on Face book this guy is bad *** Builder. Screaming Eagle race clutch with Variable pressure clutch.
Take off parts for sale. 120r 10.5.1 pistions. Very nice shape.
Hydraulic cam tensioner. with gears
266e cams
screaming eagle push rods
Forged rocker supports
Screaming Eagle rocker arms
Roller lifters
Old Apr 16, 2014 | 09:02 PM
vdop's Avatar
vdop
I don't personally have any mva numbers to show. Here's some 110 heads though. Very similar to mvas, these have a 2.10 intake valve, mvas use a 2.12. Flowed through the throttle body too.
Old Apr 16, 2014 | 11:14 PM
HD Bobber's Avatar
HD Bobber
Sounds like a badass big $$$ build.
Can't believe the 120r was so out of wack in the beginning. What fluid are you running in your primary with your SE Race clutch (I assume you have the SE Compensator, thus ATF being a no no)?
Old Apr 17, 2014 | 11:30 AM
mademoney101
6th Gear
Default 120r
I run 20/50 in the primary and do you have any before flow numbers on those heads I want to see what they were flowing out of the box. and I don't personally think those high numbers mean anything after seven hundred lift makes a difference.
Old Apr 18, 2014 | 05:12 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
If our bench here at the shop, is not to be believed in the " supreme court of the grand internet", Lazano Bros.,(.com) New Branfels, Texas, had a set of our 110"s heads on their bench, and they showed north of 330 cfm.........'bout the same we had here........
Scott
Old Apr 19, 2014 | 05:45 PM
mademoney101
6th Gear
Default 120r flow numbers
Ok guys got heads back, Didn't realize to get those numbers you had to do manifold and throttle body. wow what a differences it made .The heads flowed 361.5 the intake and i think 276.3 on exhaust, Ill post numbers latter monday. my guy hand writs every thing. the mid-rang wws really good.tha was with a 58mm body
Old Apr 20, 2014 | 07:03 PM
mademoney101
6th Gear
Default 120r
So will this build need a billet clutch basket..hummmm
Old Apr 20, 2014 | 07:24 PM
rooti's Avatar
rooti
I can vouch for Mike Lozano and Lozano brothers porting for the accuracy. Top notch shop.
Old Apr 21, 2014 | 06:34 PM
mademoney101
6th Gear
58mm throttle body. Wow, heads and intake and throttle body flowed 361 cfm and some change on the intake. Should be back together in two week. LOOK OUT.......
Old Apr 21, 2014 | 09:11 PM
vdop's Avatar
vdop
Yes. I just bit the bullet on this myself. As expensive as it is, it's cheap insurance compared to having the stock basket grenade and go through the sprocket taking out the crank, trans, primary and possibly causing a wreck depending on how it locks up. Seen it happen.
