replacement seat that moves me closer
Call them up and discuss your needs. They will take your stock seat and rework it with memory foam and gell pacs. They will move you forward too. Actuall make any adjustment you need and you will save a ton of money over a new seat. I did it and am very happy.
Anyway - I went through this problem, could reach the controls just fine but a combination of reaching down for the bars and forwards put me into the seat and could never sit back into it. Recommendations I got included changing controls to mids, seat, and bars.
What I ended up doing (after alot of thinking and measuring and second guessing) was putting Chubbys W0507's on my bike - they are 10 inch rise T bars w/ 12.5 pullback, 30.5 inches wide (same as stock width).
That solved the problem 100% - there is now no benefit for any seat or control modification, I can reach the pegs, the bars, and am pushed into the back of the seat 100% comfortable.
When I first ran into this I thought what I really needed was pullback or to be closer to the bars somehow. After measuring and looking at it I realized the #1 problem was the height of the stock bars by the time I adjusted them back (which pulls them down)..
Of course it did require a minimum of a brake line in my case, and I decided to replace all the old cables (which were getting beat) and to keep the stock cable routing.
Additionally I had to extend wiring and pull it through the bars - would be expensive at a dealer due to the internal wiring, but you could go with other bars that don't require the internal wire BS, changing cables or simply extending wiring is no big deal.
Jon
It sounds as though your position with the lower controls (shifter/rear brake) are comfortable for you as is the seat and that you want to be more comfortable with the upper controls (clutch/throttle).
Your arms should have a slight bend in the elbows so that you are not reaching and they are relaxed and not absorbing all of the front fork bumps.
If you agree, then a same height riser but with a pull-back might do the trick - an 1.5" pull-back is a very easy and non-expensive switch out thing to do as you saw in the video.
I in fact just made this same mod last week & took mine out for a 200 mile ride and loved the position - BTW I'm 6'2" with a 36" inseam
What ever you decide, after you made your mod, fill us in and let us know how it went.
Thanks. Everyone feel free to make any more comments you care to. I'll keep checking.
