Thinking About Ditching the ThunderMax...
Old May 8, 2014 | 08:24 PM
rockon's Avatar
rockon
Arrow Thinking About Ditching the ThunderMax...
...and reinstalling the stock ECM, then getting a professional tune with the Dyno Difference guys here in Dallas.
Thoughts? Anyone else had an aftermarket tuner, then gone back to the stock ECM with a good custom tune?
Old May 8, 2014 | 08:40 PM
nathanw's Avatar
nathanw
Why not just get a custom tune on the T-max? I understand it's an auto tuner but people dyne tune them to get optimized performance. Seems like a waste to spend all that money on the T-max then just remove it and replace it with something else. Is it not performing well for you?
Old May 8, 2014 | 08:44 PM
nevil's Avatar
nevil
Exactly what I was thinking. Get it dyno tuned. Whatever is making you unhappy with the way it's running can be resolved by someone who knows what they're doing.
Old May 12, 2014 | 03:54 PM
rockon's Avatar
rockon
This could turn into a pretty technical discussion...
As for my experience, the bike has always run very hot with the TMax.
I was referred to this local tuner by a couple people around here...apparently he really knows his stuff. Anyway I came to him with my inquiry and he advised that ThunderMax is essentially going backwards on a stock motor...keep in mind that mine has had no internal upgrades. When you remove the Delphi ECM you lose Speed Density and Ion Sensing. They give you no utility to "free air" calibrate the AutoTune wide band sensors so when they drift, they all do, causing it to start tuning the bike incorrectly. Apparently, when AutoTuning if you don't merge the offsets with the base map then when the sensors start to drift the tune will be terrible. He said he's pulled 15 - 20 of these off over the years and gone back to the Delphi.
Interestingly, I just talked to him today but his recommendation was the same as what I suggested in my OP...reinstalling the Delphi ECM with factory O2 sensors and getting it tuned. Curious what you guys think...
Old May 12, 2014 | 04:01 PM
latrobedyna's Avatar
latrobedyna
i use the powervision on my scooter but i love to switch to the t-max any time i can afford too.
Old May 12, 2014 | 04:07 PM
Reindeer's Avatar
Reindeer
I'm running a Thundermax and have had no issues, runs great, and has worked through all the mods I've done. I've thought about getting it dyno tuned, mostly just to make sure I'm getting the maximum power, although I have no complaints with how it runs now.
That said, if I was going to do it again I'd probably go with a PowerVision or similar. I don't like the fact that the Tmax is a completely different ECM, and if I have an issue on a road trip and I can't find a shop that stocks a Tmax I'm screwed.
Old May 12, 2014 | 04:54 PM
rockon's Avatar
rockon
That's definitely a gripe. I've never seen much from Zippers in the way of support and none of the dynos use it.
Old May 12, 2014 | 07:46 PM
HD Bobber's Avatar
HD Bobber
TMax definitely has a huge learning curve. In the beginning I was real frustrated with it not really understanding it's abilities, getting all the maps, settings, and so on.
That being said when I did my build this winter I researched the **** out of it and bugged the hell out of zippers tech to answer any questions I have had.
When used correctly there is no need to dyno it. In the TMax control center drop down after about 50 miles of riding or even 1,000 you can go in and it will tell you how much it's correcting your tune (5% range is excellent)......in there you can dump everything it learned instantly onto your tune to speed up its learning process. After few of these sessions of riding that you dump into the tuner it will make your tune perfect with barely any more changes as you ride.
If the percentages are way off in their you will know to try a new map or that something is off.
The more I have learned about this unit the better my bike runs. No other system allows you to SELF customize and tune your bike like the TMax.
If I got any other tuners I would have to get'er tuned somewhere, when I first got my pipe and breather, get a speedo healer when I regeared my bike to fix my speedo, then get a serious tune with some dyno time when I did my motor....not to mention probably have to trailer it to a shop cause I would have been able to fire it up w/o the proper map.
Really is a good system, but might be overkill IF one never plans on doing motor/trans mods.
.....also got mine used on eBay for $400 shipped!
Old May 12, 2014 | 09:19 PM
davidwideglide06's Avatar
davidwideglide06
Been running my t-max since 2006 and have had not a problem with it. The only thing I have done is changed out Oxygen sensors when I changed the exhaust to V&H this year.
Old May 12, 2014 | 10:06 PM
Bluetoys's Avatar
Bluetoys
He wants to pull a self adjusting ECM with wide band o2 sensors that is fully customizable to virtually any engine combo for a OEM ECM using narrow band o2 sensors requiring a piggyback add on controller to customize?
I respectfully suggest you seek a second opinion before you go with his idea.
