DIY cheap stand or lift
Old May 10, 2014 | 08:53 PM
soft 02's Avatar
soft 02
Originally Posted by kp877
If I could weld that's the way to go. Anyone can run a drill and a pipe wrench! I didn't even cut the wood Home Depot did it.
Hell props for even doing it! Sure better than shellin out $200 bucks on a lift. I need to make 1 more to get both wheels off the ground.
Old May 26, 2014 | 08:25 AM
br549A1's Avatar
br549A1
Someone asked if it would lift the front. I ended up adding two thin piece is plywood to it to raise it slightly higher and it lifts either the front or rear depending on where you place it under the frame. I needed the front off the ground today so snapped a pic to show it works on both ends
Old May 26, 2014 | 09:48 AM
running29psi's Avatar
running29psi
6th Gear
Thanks for sharing! I probably have enough scrap in the garage to weld up one of these
Old May 26, 2014 | 02:44 PM
okbill's Avatar
okbill
I built two for some buds at work. I used 1x1 square tubing. On the bottom, I cut a piece of pipe in half (about 2" longx1 1/2" dia) and welded it on the bottom so the lift would roll easier under the weight. Haven't taken the time to build me one yet. Go figure!!
Old May 26, 2014 | 02:46 PM
Two Feathers's Avatar
Two Feathers
DIY cheap stand or lift-image.jpgThis was one of the best $20.00 purchases I've ever made
Old May 26, 2014 | 02:49 PM
Two Feathers
Another shot of it
Old May 26, 2014 | 02:52 PM
Two Feathers
Sorry, here's the other shot.
It has 3 lift heights. The handle is also adjustable and removable.
Extremely stable and heavy duty.
Old May 26, 2014 | 03:15 PM
kreeess's Avatar
kreeess
Originally Posted by Two Feathers
Sorry, here's the other shot. It has 3 lift heights. The handle is also adjustable and removable. Extremely stable and heavy duty.
Home made? This looks good
Old May 26, 2014 | 04:08 PM
br549A1's Avatar
br549A1
Looks better than my hacked wood job! I'd buy one for $20
Old May 26, 2014 | 04:54 PM
kreeess's Avatar
kreeess
anybody heard of the black widow cruiser center stand? i think the go for $50?
