Is a 5K service DIY?
Old May 13, 2014 | 08:31 PM
nazareth27's Avatar
nazareth27
Total DIY. Service manual all the way. Do you have a lift? If not, get one, you'll need it. I use a js jack but my buddies have some full table lifts they scored at around $400. That way all your future services will be just as easy.
Old May 13, 2014 | 08:50 PM
DynaMotion's Avatar
DynaMotion
Yep like he said manual, 6 pack and easy does it
Old May 14, 2014 | 10:57 AM
thedonthere's Avatar
thedonthere
Originally Posted by heritageblue2013
Id like to add that changing all three holes (oil) is very easy and very inexpensive. $40 dollars should get you synthetic for all three.
The skills required for the work your asking about can be found on youtube and can be done by anyone. Of course the factory service manual is a plus.
As for me, I change all three hole every 5,000 miles just because it's easy and cheap to do.
it's gonna cost you around $70.00.......you'll need (5) qts of your preferred oil....2.5 for motor...1 for primary and 1 for tranny....(1) derby cover gasket...(1) oil filter...and don't forget to replace the (3) o rings on the drain plugs.
Old May 14, 2014 | 11:51 AM
sarpeezy's Avatar
sarpeezy
Thanks guys!
I figured the oil changes were next to nothing, but i wanted to make sure about those other things i pointed out earlier but i guess ill find out through service manual
Old May 14, 2014 | 12:03 PM
Reindeer's Avatar
Reindeer
I think every service on a Harley could be considered DIY. Armed with a service manual, the guidance of this forum, and a few basic tools there's little reason to take a bike to a dealership.
A jack will make it easier, but not totally necessary. I'm using a $99 Craftsman red jack modified based on instructions I found on this forum.
Old May 14, 2014 | 12:21 PM
Imold's Avatar
Imold
There are a few things in the service manual that just skip, or lack detail, on instructions, but those can be filled in by Youtube videos or just asking here. Besides the jack, I'd recommend at least a 1/4 and 3/8 drive torque wrench; even Harbor Freight cheapies beat most folks' arm guessing. The 1/4 is for case screws - they're just so easy to strip out, judging from what I've read here (I always use torque wrenches, never had that problem), and a cheap torque wrench beats a stripped out hole in a primary case. A 5 year old grandkid helps for the tight places, too.
Old May 14, 2014 | 12:40 PM
GeneseeGap's Avatar
GeneseeGap
That 5 year old grandkid of yours looks more capable than most HD techs at my local dealer and he probably had a better attitude!
Classic! great photo!
Old May 21, 2014 | 11:38 AM
sarpeezy's Avatar
sarpeezy
Hello again, just making sure before i go ahead with the oil order..
3qts 20w50 for Motor
1qt 20w50 for Primary
and 1 qt of redline tranny oil for tranny
Am i missing anything?
Old May 21, 2014 | 11:57 AM
DJY's Avatar
DJY
O-rings and derby gasket and oil filter
Old May 21, 2014 | 11:59 AM
sarpeezy's Avatar
sarpeezy
Well yea, I didnt include those because those I just have to go pick up...im ordering the oils online
