2 dumb questions
Old Mar 29, 2007 | 08:57 PM
Rocket350's Avatar
Rocket350
Default 2 dumb questions
Be easy on me, this is my 1st Harley. (07 Lowrider)
1) Is it normal to "Clunk" so loudly when shifting?
2) My left mirror vibrates so bad that it is useless. The right one is fine. Both are secure and tight. Why would one vibrate and the other not?
Old Mar 29, 2007 | 09:07 PM
Bassman's Avatar
Bassman
Default RE: 2 dumb questions
That is a signature Harley clunk...you are lucky HD didn't charge you extra for it
Can't help you with the mirror...Did you check the the ball joint where the mirror attaches to the stem?
Old Mar 29, 2007 | 09:14 PM
Timmer's Avatar
Timmer
That's not a clunk, that's just your tranny telling you it's working okay.
As far as the mirror, there was a post here a while back, a large majority of them do it. Mine does. Ya get use to it after a while.Tim
Old Mar 29, 2007 | 09:21 PM
greg3131's Avatar
greg3131
Yeh these are not crotch rockets. Your knees and back will thank you for purchasing a bike
made in America.
Greg
07 Streetbob
Old Mar 29, 2007 | 09:41 PM
DGlide04's Avatar
DGlide04
Try using a synthetic lube in the primary (not Syn 3) and the clunk may smooth out a little. As far as the mirror goes, do the handgrips on the left side also seem to vibrate too much? If so, and even if not, check the riser mounting bolts and the handlebar clamp bolts to make sure that they are all torqued properly. If they're a little too loose that may allow the left side of the bars and mirror to vibrate too much. Another thing to check is that the two screws that tighten down the clutch bracket to the bars are also tight.
Old Mar 29, 2007 | 09:55 PM
PoCoBob's Avatar
PoCoBob
My bike doesn't have a tach, when my mirrors stop vibrating I know the engine is running in it's sweet spot.
Old Mar 30, 2007 | 12:48 AM
DougsDyna's Avatar
DougsDyna
The tranny clunk is normal for a Harley......... So they tell me.
The left-hand mirror is only for semetry, and is usless.........
I think it is pretty much decided the master cylinder for the front brake dampems out a lot of the vibration in the right hand mirror.
Hate to dissapoint, but my 1985 Honda Magna mirrors did the same thing (thought there was something wrong with the bike).
If you ride so fast your eyes water, you won't notice the mirrors vibrate.
DougJ
Old Mar 30, 2007 | 01:34 AM
timdow's Avatar
timdow
My mirrordoes not seem too bad. Maybe I'm just used to it. Or maybe a good amount of handlebar provides some isolation...
Old Mar 30, 2007 | 01:37 AM
mistermooster's Avatar
mistermooster
Just bob your head up and down really really fast; the mirror will quit vibrating.
Old Mar 30, 2007 | 08:56 AM
LowriderT's Avatar
LowriderT
ORIGINAL: mistermooster
[sm=funnypostabove.gif][sm=happybounce.gif]
