Power vision O2 question if needed
Old May 15, 2014 | 04:07 PM
latrobedyna's Avatar
latrobedyna
Default Power vision O2 question if needed
Ok here it is my question i have my ECU retuned using the power vision tuner The leanest setting on my tune is 13.6 /1 AFR so it already way past the closed loop settings. That being said do i even need to have the O2 sensors in the pipes? I can not become to phantom what us they be at this point. I wanna run a set of pipes that have no O2 provision in them so would it be ok to just unhook them and forget them ?
Old May 15, 2014 | 05:02 PM
HD Pilot's Avatar
HD Pilot
I have my O2 sensors plugged up. Just had a dyno tune and the map is all open loop so I just felt no use to having my O2s in. I am a little skeptical of having 13.6 AFR as the leanest setting, that is pretty rich for cruise, my cruise is set at 14.17 AFR.
Old May 15, 2014 | 09:58 PM
target64's Avatar
target64
latrobedyna
just go into the limits & switches turn the adaptive control on 1 and closed loop off 0 and you can just plug off the o2 sensors ports im running 13.7 in my cruise area. not worried about fuel economy my spark plugs have very little color on them.
Old May 15, 2014 | 11:49 PM
latrobedyna
Originally Posted by target64
latrobedyna
Awesome thanks
ocezam
11
Oct 11, 2017 10:58 AM
latrobedyna
Jan 8, 2015 03:12 AM
Custom96
2014-2024 Touring Models
Jun 14, 2014 03:02 AM
wjl24
Nov 29, 2011 12:47 PM
depthordeath
Sep 5, 2010 09:54 PM
