Is there a difference??
Old May 18, 2014 | 08:51 PM
DJY's Avatar
DJY
Default Is there a difference??
Rotor part # 30041-08 and 30041-08A. It says the 08A version supersedes the 08. I am changing compensator and not real sure that I need to replace rotor as well. I have the 30041-08 now. Thanks.
Old May 18, 2014 | 09:44 PM
HD Bobber's Avatar
HD Bobber
You're going with the SE Compensator, right? In that case, yes, you need the rotor because the stock comp is part of the rotors as well. The new rotor us a totally separate piece.
That's what I had to do. NewCastleHd has it the cheapest.
Old May 19, 2014 | 07:28 AM
DJY's Avatar
DJY
I have the 2011 SE Comp, going to the 2014 Comp, so rotor has already been changed. Just not sure if I need to change it again for the 2014 version.
Old May 19, 2014 | 07:39 AM
HD Bobber's Avatar
HD Bobber
In that case no, since you have the older SE comp the rotor you have can stay.
vbx07
Jun 14, 2018 07:12 PM
Ygrider
May 26, 2017 07:31 AM
Not E'nuff Harley
Nov 4, 2016 05:13 PM
newdyna
Jan 27, 2016 09:28 PM
soft 02
Apr 10, 2010 01:01 PM
