Converting A Wide Glide To FL style
Old May 28, 2014 | 12:42 PM
BJ27's Avatar
BJ27
1st Gear
Default Converting A Wide Glide To FL style
I am looking to convert my 1997 wide glide to FL style. Does anyone know what front and rear fenders will work best/easiest. Going for FLH look.
Old May 28, 2014 | 05:19 PM
Robtarra39's Avatar
Robtarra39
on my 2002 superglide I used a 2000 Roadking rear fender and it fit nicely between the struts, had to fill and drill holes , on the front I used a Heritage front wheel and the front fender is designed to work with the dyna wideglide fender, also do a search for FL Dyna section and you will find all the info needed to create an FL looking Dyna
Any question just hit me up with a meesage
Old May 28, 2014 | 10:36 PM
BJ27's Avatar
BJ27
1st Gear
Is that a 7" wide fender? I have been looking around but haven't seen too many wide glides. What year heritage did you use?
Old May 31, 2014 | 07:35 PM
BJ27's Avatar
BJ27
1st Gear
any other pics or suggestions?
Old May 31, 2014 | 09:47 PM
Robtarra39's Avatar
Robtarra39
Since my bike is an 02 I went with 2000-2006 front wheel and a 99 and up rear roadking fender, for your 97 I would suggest a front wheel from a 99 or older, as for my rear fender it is 7.25 inches wide, my stock rear was 7.75 so I had to use spacers, your 97 would have a 6.75 - 7.0 inch fender, and old FLH shovelhead rear fender would fit perfectly , but try and get a 99 or older rear fender so that your stock taillight will mount up with no mods
as for the front fender you can use a Heritage fender and cut off the tabs and drill new mounting holes otherwise the fender will sit too high unless you install and FL front end
kijocoz
EVO
Oct 12, 2011 09:29 PM
byersmtrco
Dyna Parts
Apr 8, 2011 10:58 AM
dondee
Nov 24, 2010 07:33 AM
lober911
Feb 6, 2009 09:36 PM
netvampire
Mar 17, 2008 03:22 PM
