Possible fuel PAC problem
Old Jun 22, 2014 | 04:43 PM
Airborne39's Avatar
Airborne39
Stage III
Default Possible fuel PAC problem
Ok guys new to this. I have a 2009 streetbob with arlen ness bigs sucker stage 1, and vance and Hines short shots. Once I installed the FP it seems my bike is running hot. At night with it at an idle the pipes are glowing. Is this normal? I used the settings vance and Hines recommended. Is it running to rich or to lean and is there a fix. Thanks guys
Old Jun 23, 2014 | 05:09 AM
1HD1C's Avatar
1HD1C
yeah... I don't think they should be glowing.. could be the FP is screwing the timing up causing detonation or a lean condition.. I would double check to make sure you installed correct map OR get a different map.. short of that could be the fuelpack isn't working at all..
Old Jun 23, 2014 | 07:31 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
I would disengage the fuelpak and see if you still have the problem, my guess would be no.
Ranger Rick
Aug 27, 2021 10:13 PM
roadrash3
Mar 23, 2016 09:41 PM
Nick412
Jan 12, 2015 06:07 PM
Nick412
Jan 11, 2015 09:16 PM
spb209
Mar 19, 2014 08:47 PM
