Need aftermarket wheel bearing....
Old Jul 2, 2014 | 10:37 PM
Gommee's Avatar
Gommee
Devil's Advocate
I got my last bearings from Direct Cycle parts. They were a Drag specialties bearing. Go to Drag Specialties and look it up in the new Fat Book.
Check the # on the side of the bearing and go to Napa or your favorite parts store. Make sure you take your axle with you to make sure it is a 1" ID and not a 25mm ID.
Old Jul 7, 2014 | 02:41 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
I ordered a set of two from an ebay seller; $20, delivered. I'll post any useful Mgf. and p/n info here when I receive them.
Old Jul 7, 2014 | 10:35 PM
topdwg's Avatar
topdwg
Hmm, just replaced mine when I put my new rims on. How often should they be replaced? My bike has 35k on her and the bearings I pulled were not smooth when rotated, kind of gritty feeling? I went to eBay and bought a set from Boss Bearings out of NC. Put on and so far so good. Something I hadn't been checking when I changed my tire, but from now on I most defiantly will...
Old Jul 11, 2014 | 10:14 AM
PKellyMc's Avatar
PKellyMc
Rec'd the new ebay bearings yesterday; $20/pair delivered. I scanned them hi-res on my HP All-In-One and found the following info (same, both sides):
CHINA WJB DH559339-1 N129.1305
Seller (Midwest Motorcycle) p/n 95-909
Old Jul 11, 2014 | 10:58 AM
mattVA's Avatar
mattVA
When I did mine I did a lot of research. .ended up with Timken bearings from Amazon of all places. Originally bought the All ***** but they didn't appear as well made to me so I tossed them. For my bike I believe they were # 205pp. You can get them locally at a bearing supplier for an extra buck or two.
http://www.amazon.com/Timken-Bearing-Double-Capacity-Dynamic/dp/B006KSNEMC/ref=sr_1_1?ie=UTF8&qid=1405094353&sr=8-1&keywords=timken+205pp http://www.amazon.com/Timken-Bearing-Double-Capacity-Dynamic/dp/B006KSNEMC/ref=sr_1_1?ie=UTF8&qid=1405094353&sr=8-1&keywords=timken+205pp
About $13 cheaper per bearing than HD and you know it's quality.
In addition I bought the George's Garage 'upgrade' to their wheel bearing tool to supplement my Pit Posse tool. The Pit Posse didn't come with a 25mm installer pilot. Finally I bought a 'NICE' bearing for using the installer tool which comes with the JIMS/HD tool. Basically turned the Pit Posse tool into the exact same JIMS/HD setup for a fraction of the cost.
Old Jul 14, 2014 | 06:22 PM
RonRock's Avatar
RonRock
http://www.amazon.com/Timken-Bearing...s=timken+205pp
Good help there. Thanks for the info. Can you tell us more about the upgrades you did to the PP tool? I recently bought one and used it once, would like to do anything I can to make it even better.
Old Jul 15, 2014 | 06:34 AM
mattVA's Avatar
mattVA
Sure.
If you take a look at the JIMS wheel bearing tool instructions: http://www.jpcycles.com/instructions/pdf/910-679.pdf
You'll notice the Pit Posse tool is identical save for #8 and it is also missing a 25mm collet for installing the bearing(s).
You can buy the SKF NICE 603 bearing off eBay, etc. I got mine on eBay. Shipping was more than the price per bearing so I bought 2 and gave the other away.
To address the 25mm collet for installing the bearing, George's Garage sells an 'update' kit for the 25mm bearings intended to be used with their tool, but since the dimensions are all essentially the same for Pit Posse, Georges, HD, JIMS, you can buy it and use it with the Pit Posse tool:
http://www.georges-garage.com/chassis_tools.htm
#740030
So for about $140 you would have the same tool as the more expensive brands at a fraction of the cost.
I followed JIMS instructions when using the tool since it addresses how much torque to apply when installing the bearings, where to apply lubrication, etc.
Old Jul 15, 2014 | 05:37 PM
Black Bart's Avatar
Black Bart
I'm marking this page for future reference. Thanks for the info all.
Old Jul 16, 2014 | 09:55 PM
archergodwin's Avatar
archergodwin
Sorry I didn't see this before Pat... yep Timken 205PP...
I am actually looking into the Timken 5205KE... very tempting to try and see if it will work. ... 5.6mm wider.. obviously some work on the wheel spacers, and the bearing spacer... but to have a dual row bearing... that's pretty tempting...
Old Jul 17, 2014 | 04:28 PM
PKellyMc's Avatar
PKellyMc
yeah...agree.
sbrmike
Wheels/Tires
Mar 9, 2018 04:20 PM
'11 SGC rootbeer
May 31, 2015 01:39 PM
brihvac
Apr 24, 2012 07:50 PM
Scouser1
Mar 20, 2012 08:26 AM
07bobber
Jan 3, 2010 09:09 AM
