And yes, it's a carbed bike. I guess I'll pull the carb and check the seal. Thanks.
If you pull the carb, put a new seal ring on unless it's fairly new. They loose their elasticity and get squished after a while and may not seal right when you reuse an old one.
Looks like a short or loose connection. The lights changes with the engine. Maybe a bad ground
Check your battery connections, and resistance from negative post on battery to the frame, if they are OK then focus on alternator/regulator as you can see from the headlight there is a voltage drop.
