I put on a seat of Kury............I like the LED indicators fo rthe fuel and battery better than others I saw, including the HD ones.
If you do go with Kury I'd suggest ordering from Eastern Performance Cycles [one of our sponsors]. They are a huge Kury distributor and haev far better prices than you will generally find elsewhere....plus a very good group to deal with.
r racer
i will take any help you can give. like does the wiring match up? if not which color goes to which? did the parts slide in to the hole the same? did you have to change the fuel sender unit?
thanks
tl
The fuel sending unit is the same and for me all of the parts fit like a glove. The only thig about my setup is Im using a 06-07 tank . But when we search the part# s the sending unit was the same one for the 03 and the 07.It might be even easier for you than it was for me because I was switching from a superglide to a wideglide. What I did and you may not have to was cut the cable that went to the gauge from my old tank about 6 inches past the connector. Then I had to splice the black wire from the flush mount gauge and the black wire from the sending unit with the black wire in thepeice I cut off with the factorypigtail. then I splice the red from the gauge to the factorypigtail. then you splice the yellow wire from the sending unit to the yellow wire on the gauge. Thats it!
