Leaky Primary Case?
Old Jul 26, 2014 | 09:01 PM
Kaycee's Avatar
Kaycee
Clean it all up remove all oil residue and then take a good long ride.When you get back grab a small mirror and a flash light and u should be able to see the trail.Thats a reason why I like to run a different color oil RED LINE Shockproof in the trans.That way you know if its a primary seal or trans seal.
Old Jul 27, 2014 | 08:07 AM
WideGlideFever's Avatar
WideGlideFever
Thanks for all the inputs guys. I wish I was in a better position do deal with this but like I mentioned earlier, Im back home with the wife and kids. When I get back to Cali I wont have enough time to try and get this fixed before I head out on deployment. As much as I hate it, reality is I am going to have to take it to the dealer.
Normally I do run Red Line in the tranny, just so happens this last time I put in something different.
I will post up what it turns out to be, but its going to be a couple weeks until I get back to Cali.
Old Jul 28, 2014 | 09:30 AM
JRK5892's Avatar
JRK5892
i would guess that it is the inner primary bearing seal then... do you have any fluid off your front pulley?
Old Jul 30, 2014 | 07:52 AM
WideGlideFever
Didnt see any signs of fluid coming off the front pulley.
Old Jul 30, 2014 | 12:23 PM
JRK5892's Avatar
JRK5892
perfect!
Old Jul 30, 2014 | 05:17 PM
WideGlideFever
Originally Posted by seniorsuperglideE8
The shift shaft seal is a rubber seal that the shaft goes through, this shaft rotates for every shift you make, eventually wearing on the seal and lettting some trans oil out. If you have access to UV oil dye put an ounce in the tranny, go for a ride then hit it with a black light. If it glows then you know what cavity is leaking.
Showed the pics to my buddy here in P'cola; he is a former HD Mechanic (former by choice ) and he is thinking the shifter seal also. I am hoping that is the case, sounds like the cheaper of the two between that and the primary main seal.
Will post up what the problem actually was in a couple weeks
Old Jul 30, 2014 | 05:33 PM
mirrmu's Avatar
mirrmu
Hi,
When i had mine apart the shifter shaft seal was almost non-existent but not leaking,
Any oil drops/splatter on debris deflector? Have you checked transmission fluid to see if it is a bit down on the stick?
The problem with this type of leak is that the dealer will want to change everything at quite a cost when may not be required, main seal gets mentioned and may well be worst case but i reckon there just as many out there that are the inner bearing race walking outwards
Thanks
Mirrmu
Old Jul 30, 2014 | 09:48 PM
WideGlideFever
Originally Posted by mirrmu
Hi,
Thanks
Mirrmu
I didnt check the fluid levels yet, that will be first thing on the list when I get back to Cali. I will have to look for the debris deflector, didnt realize I had one or where it is located (im still learning).
I get what you are saying about the dealer changing everything; I actually want to talk to my buddy some more and have him give me a list of what should be checked in order for the problem. Instead of the dealer just going labor happy and changing all kinds of stuff that may not need to be changed.
Old Jun 9, 2015 | 04:44 PM
Redbeard's Avatar
Redbeard
What did you end up doing about the leak? I think I'm experiencing the same thing on my 2011 WG.
Old Jun 9, 2015 | 05:00 PM
Gliden's Avatar
Gliden
Over the winter I went after a leak that I thought was the primary but it was the oil pan seal. All the bolts had vibrated loose over 36k and the oil was seeping out the gasket and blowing all over making it difficult to find.
I finally decided to spend a few hours removing every oil pan bolt, thread locking and reinstalling them and leaving them kinda loose until I followed up with the proper tq sequence and tq spec. I'd say most all of these oil pan bolts were loose and some pretty damn loose.
I don't have a single drop of any oil anymore outside my bike.
underdog
33
Oct 25, 2021 02:02 PM
Pagman
Oct 21, 2012 07:24 PM
Doug S
EVO
37
Mar 18, 2010 04:26 AM
SBJJC
Feb 26, 2010 12:21 PM
FireRyder09
Nov 5, 2009 10:53 AM
