When Do you Shift?
Old Aug 11, 2014 | 10:50 PM
  #41
MRFREEZE57's Avatar
MRFREEZE57
I always run in as high of gear I can without the engine jerking and lurching.
This will get you the best gas mileage. since I added a FL-VIED, now have a lower exhaust temp, but the engine seems more stable at lower rpm. I can ride in 6th gear at 50mph without surging or jerking.
Old Aug 11, 2014 | 11:05 PM
  #42
fxdlx's Avatar
fxdlx
Originally Posted by HD Pilot
And nobody would ever go faster than the speed limit
My bike feels fine at 4000+ rpms, not sure what is wrong with yours
Old Aug 11, 2014 | 11:12 PM
  #43
2500hdon37s's Avatar
2500hdon37s
that will not net you best gas mileage because thats farther away from where the engine makes it's peak and most efficient power.
Old Aug 11, 2014 | 11:16 PM
  #44
Freebirdsride1's Avatar
Freebirdsride1
I've always tried to stay within the engine load to the gear in use, like down-hill up-hill head-wend or tail-wend it all makes for engine load. let the engine load tell you the optimum gear to use.
Old Aug 11, 2014 | 11:21 PM
  #45
2500hdon37s
Shifting is entirely based on the situation. Aggressive riding and speed I shift about 4800-5k, around town with traffic I'll take it to 3500.
I usually cruise at 1900-2300 if I'm taking a very relaxed just boppin' down the road cruise, going to work is usually around 2600-3000, and on an aggressive run through some curves Its around 3-4k where the engine makes it's peak power.
I'm gonna try to keep my engine at a little higher RPM like 3000 around town and going to work to see if MPG picks up.
And to all the guys cruising at 45-50mph in 6th.... just because the bike can do it doesnt mean you should!
Old Aug 11, 2014 | 11:24 PM
  #46
2500hdon37s
BINGO, that'll also net the best MPG and least wear and tear.
  #47
brandon95354's Avatar
brandon95354
So riding at peak power makes the best fuel mileage? I would think I get horrible mpg at peak power.
Old Aug 11, 2014 | 11:59 PM
  #48
Id.Fat Bob's Avatar
Id.Fat Bob
Most engines get the best mileage at peak torque...not peak HP!
Old Aug 12, 2014 | 12:19 AM
  #49
ynots's Avatar
ynots
Originally Posted by 07_Dyna
I don't hit 5th until 40 mph. The bike seems happy the way I do it. When I get my tach going I'll know.
Id hurry up and get that tach
Old Aug 12, 2014 | 03:47 AM
  #50
DonN's Avatar
DonN
I rented a heritage classic last month while in Cali. With stock exhaust, it was really hard to tell when to shift as its soo quiet. And the bike felt buzzy in the grips if I tried to run it hard, so probably was shifting too soon.
