When Do you Shift?
Old Aug 13, 2014 | 01:13 AM
  #61
loopie's Avatar
loopie
Originally Posted by shiftace
Pretty much on the limiter. Always. Why tachs even have 1-5k is beyond me.
great answeror when the wife slaps my helmet (back off head)
Old Aug 13, 2014 | 06:22 AM
  #62
Warp Factor's Avatar
Warp Factor
When my wife got her own bike, she asked when she should shift.
I told her,
"Whenever you feel like it. Don't worry about it. If you go too high, the limiter will take care of it."
We switch off between bikes some though, and I think we both keep the Dyna above 2500 rpm most of the time just to keep the vibration down. Except that sometimes the vibration feels good, so what the heck?
Old Aug 13, 2014 | 07:04 AM
  #63
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Originally Posted by Warp Factor
Why??
Lugging.
Old Aug 13, 2014 | 07:49 AM
  #64
Jeff's 1st Harley
I told her,
Why ?
Old Aug 13, 2014 | 08:08 AM
  #65
Warp Factor
Originally Posted by Jeff's 1st Harley
Lugging.
"Lugging" is kind of an archaic term which doesn't apply very well to engines with modern electronic controls.
Way back when, a combination of low rpm and high throttle opening could result in detonation, which could be very destructive. Not something one needs to worry about much any more, with detonation sensors, electronic timing retard, manifold air pressure sensors, etc.
So what exactly do you mean by "lugging" a computer controlled engine, what is the harm done, and what is the mechanism behind the harm?
Old Aug 13, 2014 | 08:21 AM
  #66
Warp Factor
Why ?
Why do we usually run 2500 rpm or higher on the rubbermount bike? Strictly for comfort. With the compliance chosen for the mounts, that happens to be the point where less vibration is transferred to the rider.
On the other bike with the balance shaft engine, we often run lower rpms than on the Dyna, since vibration felt by the rider is about the same at any rpm.
Old Aug 13, 2014 | 09:35 AM
  #67
HD Pilot's Avatar
HD Pilot
I admit this is an interesting point but it is the first time that I have heard that lugging is not a problem. I think I will stick with the crowd and not lug, I do not think all the things you mentioned can keep up with poor riding decisions. Not trying to irritate, because I love to hear from contrarians!
Old Aug 13, 2014 | 09:45 AM
  #68
JamesRHey's Avatar
JamesRHey
What you describe makes perfect sense, but I've always referred to the jerking motion of an engine in a high gear at a low speed as 'lugging' also. Not much of a dilemma at highway speeds, but when cruising around town if I end up in 5th gear doing 45-50mph, and do not downshift when slowing to a stop (say at a stoplight). If I stay in 5th gear and the bike gets to 20mph or less the engine will lurch back and forth right before stalling (it's been a LONG time since I've made this mistake, so I'm guessing on the gear and speed, but you get my point.) Always thought of that sharp jerking as 'lugging'
Old Aug 13, 2014 | 10:07 AM
  #69
Texas_Rider11B's Avatar
Texas_Rider11B
I've got a TC-88 and no tach so I do it by ear.
Old Aug 13, 2014 | 11:10 AM
  #70
Warp Factor
It doesn't really have anything to do with poor riding decisions. Many modern cars are now going down the freeway at about 1500 rpms, to improve fuel economy and decrease wear, and these engines are lasting longer than ever. My supercharged Corvette is turning about 1200 rpms cruising at 70 mph. No harm, not even if I hold the throttle to the floor for 15 minutes going up a mountain at that rpm.
Even Harley has dropped top-gear highway rpms quite a bit on their bikes in the last eight years, after they got some pretty sophisticated computerized controls.
"JamesRHey", sure, if you try to drive the bike below idle speed, it won't run very well. And you may not be able to go very low if you have aftermarket cams. I've had a couple of cars with big cams that were pretty much undriveable under 2000 rpm. But both my Harleys (stock cams) drive fine at idle rpm.
