When Do you Shift?
Old Aug 12, 2014 | 05:04 AM
  #51
Deanos103's Avatar
Deanos103
Stage II
Around 2500 - 3000 rpm and never into sixth before 100k (60mph)
Old Aug 12, 2014 | 06:07 AM
  #52
major105bc's Avatar
major105bc
Shift between 3000-3200. Cruise between 2500-2800. Don't usually go to 6th until 65-70 mph.
That's what my bike tells me to do. I use my tach a lot. It becomes a habit.
Old Aug 12, 2014 | 07:23 AM
  #53
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
After you shift look at the tachometer. Never let the rpm's drop below 2000 under a load keep it above that and your good to go.
Old Aug 12, 2014 | 08:58 AM
  #54
My2Harleys's Avatar
My2Harleys
My manbual says:
15 mph 2nd
25 mph 3rd
35 mph 4th
45 mph 5th
55 mph 6th
Down shifting
50 mph 5th
40 mph 4th
etc
Old Aug 12, 2014 | 09:29 AM
  #55
rick-e-b's Avatar
rick-e-b
Its impossible to list a shift point, only the engine can tell you when to shift. When I'm lazily cruising on residential streets I short shift at low rpms ( who needs to keep it in first gear in a 25mph neighborhood) When merging with interstate traffic I wind it out quite a bit more. My Road Glide is happy at 55 in 6th gear as long as my speed is stable. If I'm riding aggressively weaving traffic I must use a lower gear. Trying to get people to list is shift point is a suckers question. If you need to ask, then you need to practice your riding skills.
Old Aug 12, 2014 | 10:41 AM
  #56
DJY's Avatar
DJY
Not that low rpms are good for motor, but I would think the less rpm, the less fuel being used. Why do you think cars have over drive?
Old Aug 12, 2014 | 12:08 PM
  #57
Warp Factor's Avatar
Warp Factor
Originally Posted by Jeff's 1st Harley
After you shift look at the tachometer. Never let the rpm's drop below 2000 under a load keep it above that....
Why??
Old Aug 12, 2014 | 12:13 PM
  #58
shiftace's Avatar
shiftace
Pretty much on the limiter. Always. Why tachs even have 1-5k is beyond me.
Old Aug 12, 2014 | 12:41 PM
  #59
Juggerpops's Avatar
Juggerpops
Just messing around bit practicing counterstearing this afternoon so I watched the tach display shift points between 2500-3000 rpm sound and feel must be right on also noticed cursing at 35 mph in 3rd rpm are at 2500 rpm
Old Aug 12, 2014 | 10:09 PM
  #60
MRFREEZE57's Avatar
MRFREEZE57
Originally Posted by 2500hdon37s
that will not net you best gas mileage because thats farther away from where the engine makes it's peak and most efficient power.
although this is the first HD i have owned, any other bike, or auto for that matters I always seem to get better gas mileage then others can achieve which am sure is due to I always run in the highest gear the machine can run without lugging or jerking.
