front breaks "popping"
Old Aug 14, 2014 | 02:24 PM
huskytamer's Avatar
huskytamer
Default front breaks "popping"
Hey folks I am hearing a popping noise when I engage my front brakes on deceleration. I just put a new 21" wheel on the front this season and it came with a new rotor premounted. I have never heard this before installing the new wheel but I'm wondering if my caliper is dirty of if my brake fluid is bad. when I installed the wheel I put in new brake pads and everything lined up perfectly. The bike stops fine and the caliper engages and releases but the noise has me concerned. Any input would be appreciated.
Old Aug 14, 2014 | 02:46 PM
WMX124's Avatar
WMX124
Check front axle assembly and caliper. Jack the bike up and spin the wheel then apply the brake. See if anything moves or if you can track down the sound.
Old Aug 14, 2014 | 03:06 PM
maddghost's Avatar
maddghost
if this rotor has alot of holes drilled into it for cooling purposes then the noise you hear is normal. I remember when O bought my bike I didn't want to use my front brakes because I didn't like that sound, well let me tell you my rear pads went out in no time and warped my rear rotor.
Old Aug 17, 2014 | 10:12 PM
huskytamer's Avatar
huskytamer
Yes it has way more holes in it than the stock rotor. Thanks for your input.
Old Aug 18, 2014 | 11:10 AM
misfitJason's Avatar
misfitJason
Has it been sitting awhile? If so the seals can get dry and when the puck is retracting that can also cause the popping noise but generally will go away with use and they get re-oiled per say. More than likely it is the noise from your drilled rotors
RHillbilly
EVO
Sep 30, 2015 04:43 PM
mikemock
Jun 19, 2013 09:03 PM
jimmers1817
May 2, 2011 06:01 PM
slammer66
Nov 22, 2010 01:07 AM
MOSTWANTED
Sep 18, 2008 02:23 PM
