Rake and Triple Trees
Old Apr 8, 2007 | 02:31 PM
deeblues's Avatar
deeblues
Default Rake and Triple Trees
Does anyone know if the frame and steering head is the same for a 2007 bob or wide glide???
Do they get the rake difference at the trees???
And how much wider are the trees on a 07 wide glide versus a 07 St Bob????
Be nice to have a wide glide front end on a bob if all you have to do is change the (2) trees.....
After all fatter is always better.....well except in WOMEN.....LOL
[IMG]local://upfiles/23685/D8F48EBE58F344858108F050BB1BF616.jpg[/IMG]
Old Apr 8, 2007 | 04:46 PM
Trotter's Avatar
Trotter
Default RE: Rake and Triple Trees
3 Deg in the neck and 2 deg in the trees
Old Apr 8, 2007 | 09:57 PM
steelcowboy's Avatar
steelcowboy
So what kinda difference would it make changing to the wideglide trees?
Old Apr 8, 2007 | 10:10 PM
rodnreel's Avatar
rodnreel
SB's have 4.7" of trail. Ideal range, from what I've readis 4-6". If you add 2 degrees of rake, you'll reduce your trail. I used an online calculator when I was condsidering doing the same project and came up with 3.5" of trail.
A little less than ideal, but probably not unsafe. The bike will be easier to handle at slow speeds, and tight turns. But at higher speeds may feel a little less stable.
Here's a good link:
http://www.rbracing-rsr.com/rakeandtrail.html
Old Apr 8, 2007 | 10:17 PM
Zyklon's Avatar
Zyklon
It seems like a least two or three forum members have installed a Wide Glide front end on their Super Glide / Street Bobs, try a search and see what you get, or try this link. It will show you Wide Glide triple trees, stock length fork tubes and a 21 inch front wheel.
on a green 06 Low Rider.
https://www.hdforums.com/m_814521/tm.htm
Good luck with it.
Zyklon
Old Apr 8, 2007 | 10:18 PM
steelcowboy
BUt will it look cool? LOL I mean its that or a chopper kit I can't stand it looking so short much longer
Old Apr 9, 2007 | 12:21 AM
TOMMAY's Avatar
TOMMAY
If you want a little length without changings triple trees you can just use the WG upper tubes and springs,makes a good bit of visual difference without much change in handling.
Good Luck
Tom
Old Apr 12, 2007 | 12:53 AM
WS6 Formula's Avatar
WS6 Formula
ORIGINAL: deeblues
06 / 07 Wide Glide steering head is 34*, and has 2* triple clamps. All other 06 / 07 Dyna'sare 29*, and 0* triple clamps, except the Low Rider whichhas a1 1/2* triple clamp.
06/07 Wide glide is 1 1/2" wider then the other 06 / 07 Dyna's
You will also have to get a wider hub or find a 06 / 07 21" Wide Glide wheel / tire set up on eBay.
Old Feb 1, 2008 | 10:21 AM
Redbeard's Avatar
Redbeard
I see a lot of late model Dyna folks using WG trees. How do they compare to Softail trees? Same width, but what about rake? Are they a direct swap like the WG trees?
Thanks
Old Feb 1, 2008 | 10:27 AM
Muddyape's Avatar
Muddyape
No softail trees on new dyna's. 06+ have 49mm tubes, not sure what softails are but arent 49mm. Probably 41mm so I would say no to direct swap. WG swap is cheap (relatively speaking)and easy.
