New seat. how to remove threads
Old Sep 5, 2014 | 08:49 PM
apetterez's Avatar
apetterez
Default New seat. how to remove threads
I know it's probably super easy but how do I remove the female thread that holds my seat to the rear fender. I got a new seat and need to relocate the threads since I'm going from 2 up to solo
Old Sep 5, 2014 | 08:53 PM
QC's Avatar
QC
Typically, that threaded hole just gets plugged. The nut on the underside of the fender is semi-permanently mounted.
Old Sep 5, 2014 | 09:01 PM
Smokey Stover's Avatar
Smokey Stover
Pop that 'E' clip and it will drop down onto the tire, Installs easier with a long zip tie through it and up n out the hole. At least on a touring model.
Old Sep 5, 2014 | 09:44 PM
sgr60's Avatar
sgr60
Same on a dyna - super easy.
Old Sep 5, 2014 | 10:25 PM
IdahoHacker's Avatar
IdahoHacker
Yup, the E clip, or circlip, comes right off and then the female part just drops down through the hole. The clip usually comes off so easily that you can do it with your fingernail.
The easiest way to replace it is to fish a string or piece of wire down through the hole, then put the string through the hole in the nut, tie a washer or anything similar to the bottom of the thread or wire so the nut doesn't fall off, and then just pull it back up through the hole, and put the clip back on.
Old Sep 6, 2014 | 12:00 PM
hvacgaspiping's Avatar
hvacgaspiping
`Just did it on my sig bike a few weeks ago.
Old Sep 6, 2014 | 01:31 PM
Silvio's Avatar
Silvio
Why do you need to remove the threads?
Are you relocating to another hole for the new seat?
Old Sep 8, 2014 | 08:39 AM
apetterez's Avatar
apetterez
That is exactly what I am doing .do you know how to do it?
Old Sep 8, 2014 | 09:06 AM
maddghost's Avatar
maddghost
At least three guys already told you above. there is a small plastic C-clip holding ametal plug. push the c-clip back the metal plug falls, or you could get your hand in thtere and catch it, maybe, pass it through the desired hole with a long ty-wrap and re-clip it. Two minutes max.
On the other hand if you want to switch back and forth just buy a new one for 5$ or less and have both.
Old Sep 8, 2014 | 09:50 AM
DJY's Avatar
DJY
I know this is probably not needed but... Do you have eyes?
