Best led mirrors
Old Sep 7, 2014 | 08:20 AM
Cmdixon's Avatar
Cmdixon
Default Best led mirrors
I'm looking for some led mirrors for my SB. If anyone has them, post a picture. Or a link. Thanks
Old Sep 7, 2014 | 03:15 PM
Chicago Ken's Avatar
Chicago Ken
I would like to try the mirrors from a V-Rod. Don't know if they would work on my 2010 Fat Bob.
Old Sep 7, 2014 | 03:40 PM
Cmdixon's Avatar
Cmdixon
Do they look like this
Old Sep 7, 2014 | 04:24 PM
Chicago Ken
Not like that. Those probably would work better than the razor style I have.
I would like to try the mirrors that come stock on the V-Rod Muscle. They look like this.
What would be involved in getting them to work? The stock Dyna signals have three connector wires. The V-Rod only has two wires.
I saw someone use Custom Dynamics LEDs taped under the hand controls on their bike a while back. Looked pretty good.
I can't find the link now that I considering going that route. Don't know what would be involved in them getting to work.
Old Sep 8, 2014 | 01:24 AM
rogersachs's Avatar
rogersachs
Smile
Have Rivco and like them . Work well and are easily seen. Leds front and rear. Have used them on my last two harleys.
Roger
Old Sep 8, 2014 | 02:41 AM
adm's Avatar
adm
I have the HD LED mirrors / turn signals on my bike and like them a lot.
The only negative to them is that they don't have a telltale on the glass side of the mirror, so you can't see if it's flashing or not. But then again, there's already a telltale in the instrument panel.
They also have only two wires - power and ground, but function as running lights (so LEDs always on), then flash for the turn indication.
They come with a set of "Y" harnesses that connect the mirrors to the stock wiring. There is a small circuit board in the the Y harness that presumably takes the three wire input and converts it to a two wire feed to the mirrors.
Old Sep 8, 2014 | 04:59 AM
Dyna_Bagger85's Avatar
Dyna_Bagger85
I'd like to know how to wire up a set up the V-Rod muscle mirrors as well.
Old Sep 8, 2014 | 07:48 AM
spyderwebb's Avatar
spyderwebb
I installed the V-Factor LED turn Signals and I am happy with the results.
They are a 3 wire light, install wasn't to bad... the hardest part is getting to the harness in the frame under the tank. You have to fish them out through the openings which are plugged at the neck of the bike.
They function as a running light, then blink when turn signal on, and they have an LED indicator light for the turn signal function in the mirror side (3 small red lights blink)
Attached Thumbnails Best led mirrors-photo-4.jpg   Best led mirrors-photo-5.jpg   Best led mirrors-vfactor-turn-signal-mirrors-2.jpg   Best led mirrors-img_0724.jpg
Old Sep 8, 2014 | 08:15 AM
adm's Avatar
adm
It's a lot easier if you take the tank off and drop the wiring out through the bottom of the frame top rail. There's a little elastic door type thingy you can pull out and then get good access to all the wiring.
Old Sep 8, 2014 | 10:16 AM
spyderwebb's Avatar
spyderwebb
You are correct, I did that too, but because I wanted to run the new turn signal wires in the existing shrink tube (that houses all the other wiring) I needed access from both sides to fish the wire through with a hanger.
