scary noises
Old Sep 8, 2014 | 07:51 AM
Bmatt's Avatar
Bmatt
Default scary noises
took the bike2012 streetbob with about2500 miles to lunch yesterday(quick ride)on the way back after going threw some twistiesheard a metalic sound coming from front of the motorcycle not really a gringing not a squeeling. went straight home put the bike on the lift spun the frnt wheel nothing spun it again harder and lightly applied brake nothing, check the spokes all seemed tight, held the forks and tried twisting the wheel good, checkedfront motor mount tight. went for ride around neighborhood and killed the motor to listen for noise and it wasnt there.Now Im aliitle nervous to take the bike for a real ride becouse the noise came from frnt end area. any suggestions
Old Sep 8, 2014 | 09:48 AM
kcflhri's Avatar
kcflhri
Rock under fender??
Old Sep 8, 2014 | 10:25 AM
rjo3491's Avatar
rjo3491
could it have been road noise? we have a stretch of freeway here in metro Detroit where they tested some new European concrete that's supposed to be good with ice. it wasn't, and, it makes the most God awful sound you can imagine when you ride over it.
Old Sep 8, 2014 | 12:01 PM
nevil's Avatar
nevil
So far you told us it's not grinding or squealing, so what does it sound like?
Could be loose heat shields or tank bolts not tightened down all the way. Check that the exhaust pipe flanges are not loose.
Old Sep 8, 2014 | 01:43 PM
Bmatt's Avatar
Bmatt
def not road noise been on that stretch hundreds of times not exhaust or heat shields nloose it was a very weak grinding sound
Old Sep 8, 2014 | 01:45 PM
nevil's Avatar
nevil
Is it speed related or rpm related and does it happen in every gear?
Old Sep 8, 2014 | 02:56 PM
californiafatbob2013's Avatar
Default Check Exhaust Flange Nut's...........
This happened to me while riding in the hill's.........
Heard some metalic noise pulled over and found my exhaust flange nut's had backed off...........just enough to make noise as I was hitting the little bumps in the road..........
Live Free = Ride Free.........
Old Sep 8, 2014 | 03:47 PM
ghira75's Avatar
ghira75
was it a metallic sound like "tin tin tin " and it happen when accelerating ?
That would be a pinging indicator
Old Sep 8, 2014 | 06:35 PM
Bmatt's Avatar
Bmatt
not speed related i dont think was kinda hard to hear the faster i rode not rpm related and when i went for a ride later i could not her the noise it has seemed to stop for now i guess
Old Sep 8, 2014 | 07:02 PM
JRK5892's Avatar
JRK5892
Man I would love to help but to be honest you have not given us much to go off of to point you in the right direction to resolve the issue, could be neck bearings ,could be wheelbearings could be a stock piston in your caliper, could be a loose pad in your caliper, could be a loose motor mount a loose heatshield could be a loose intake mount, could be loose riser bolts, could be the plug inside the headlight came loose, The sky is really the limit until you get a little bit more descriptive on what causes the issue, specifically what it sounds like, and from there we can help you resolve the issue. Just let me know I'm happy to help
