Carb issues
Old Sep 14, 2014 | 10:04 PM
JeepsandHD's Avatar
JeepsandHD
Default Carb issues
I have a 2000 LR. Used a Genuine James kit to rebuild the carb. The bike starts fine and idles fine but when I get on the throttle it dies. Only way I can get on the throttle is if I leave the enricher out, and then I can only do it once. Where did I mess up?
Thanks, Mike
Old Sep 15, 2014 | 08:39 AM
JeepsandHD's Avatar
JeepsandHD
I should say that I rebuilt the carb because I lost my acceleration and had difficulty maintaining highway speeds when going up slight hills.
Thanks
Old Sep 15, 2014 | 10:04 AM
Foxster's Avatar
Foxster
I's whip the top off again and check you didn't snag the diaphragm during reassembly.
Old Sep 15, 2014 | 10:18 AM
JeepsandHD's Avatar
JeepsandHD
I will give that a try.
Thank you!
Old Sep 15, 2014 | 12:26 PM
sengle4's Avatar
sengle4
Default carb issue
Also check for pinholes in the diaphram. Is the accelerator pump squirting fuel as it should?
Old Sep 15, 2014 | 01:09 PM
fdh161's Avatar
fdh161
Did you replace the main jet? I just rebuilt the CV on an older Sportster that had the same problem an your original (maintaining speed). Turned out the main jet had somehow accumulated enough gunk to restrict full fuel flow. Doesn't take much to obstruct enough to matter. Don't bother trying to clean it. They're only a couple of bucks. Put in a new one of the right size.
Chances are, though, it's what the previous poster suggested. Pinched diaphragm or pin holes.
Old Sep 15, 2014 | 01:33 PM
JeepsandHD's Avatar
JeepsandHD
Didn't see any pin holes (holding it up to the light method and yes, accelerator nozzle was shooting out gas (never realized just how much gas shoots out).
I did not replace the jets, but they were clean (probably should have replaced though).
Old Sep 15, 2014 | 07:10 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
While the bike is idling and the air cleaner off so that you see the carb throat, turn the throttle and notice if the slide is going up to allow more air and fuel. How many turns do you have the idle mix screw turned out? start out at about 2-2 1/2 turns.
pacman552sd
Carburetor Related
Jun 3, 2015 10:39 PM
flh04087
EVO
Sep 13, 2012 08:51 AM
Bama91
EVO
18
Jun 12, 2011 03:24 PM
Fossil
EVO
17
Nov 5, 2010 08:34 PM
Pauly
Exhaust System Topics
Jun 8, 2006 10:48 PM
