carb popping
Old Sep 12, 2012 | 03:15 AM
flh04087's Avatar
flh04087
Default carb popping
My carb seams to pop and have hesitation at cruising speed , seams fine at idle and when i get on it if but if i just sit at say 50 it has the occasional pop pop pop any ideas oh ive checked for leaks
Old Sep 12, 2012 | 04:56 AM
badcooky's Avatar
badcooky
Might be slightly lean on cruise man.
Old Sep 12, 2012 | 07:14 AM
miacycles's Avatar
miacycles
What type of carb, bike, and what mods ?????
John
Old Sep 12, 2012 | 02:26 PM
flh04087's Avatar
flh04087
84 evo ,cv carb
Old Sep 12, 2012 | 03:39 PM
mostSilly's Avatar
mostSilly
Does it Pop more When decell going down hill?
Old Sep 13, 2012 | 04:47 AM
aaamax's Avatar
aaamax
sounds like some dirt is in there. doesn't take much, just a speck in one of the jets and that's what you get.
Old Sep 13, 2012 | 08:51 AM
lieutenant G's Avatar
lieutenant G
I chassed this problem for over a year on my evo, It is a lean problem caused by either an air leak, lean jetting or both.
First replace intake seals and the seal from the carb to the manifold. second (since the carb is off) replace the OEM needle with a 88XL needle. This will richen up the mid range RPM. Check the jetting while you're in there. With an air cleaner and exhaust, I would run a 46-48 and 180-185 but would be guessing. If you dont dyno it get a few sets of cheapo plugs and do plug checks with various adjustments.
kansasroadking
Exhaust System Topics
Jan 20, 2024 09:42 PM
98fxdwgcmc
EVO
13
Jul 22, 2016 12:34 PM
pacman552sd
Carburetor Related
Jun 3, 2015 10:39 PM
Motorcycho
Apr 7, 2006 12:07 AM
Beeracuda
13
Dec 27, 2005 03:16 PM
