Intiminators... what a difference!
Old Sep 15, 2014 | 08:51 PM
vern58's Avatar
vern58
Default Intiminators... what a difference!
Took the first ride last weekend after installing a set of Intiminators in my 12' WG and man do they make a difference in front end handling. No more feeling every expansion joint, no more wheel hop when encountering a poor road surface on cornering. Front tire feels glued to the road. Overall they provide much better front tire contact while soaking up a fair amount of normal road imperfections.
Highly recommended upgrade!!
Old Sep 16, 2014 | 01:01 AM
ShiftyCapone's Avatar
ShiftyCapone
What are your specs? Spring rate, spacer length, oil type, oil level, measured sag, etc.
Not trying to grill you or anything, just curious because you're the first person I've seen with a newer model WG that is very happy with their setup...
Old Sep 16, 2014 | 06:10 AM
vern58's Avatar
vern58
Stock springs, spacer shortened by 5/8" & Amsoil 10wt. Shock Therapy. Winter mods may include swapping out stock springs to non-progressive when I do the rear shocks, but I wanted to try this quick fix first. Overall I'm quite pleased with the results with a minimal investment.
smokingjoe
Apr 2, 2017 06:41 AM
Bubba Zanetti
Sep 22, 2016 09:18 PM
mossenheim
Jan 23, 2013 09:07 AM
fireaxxe
Oct 22, 2011 05:30 PM
creep1
Jul 22, 2008 07:42 PM
