Wiring issue
Old Oct 31, 2014 | 09:55 PM
andyshd's Avatar
andyshd
Default Wiring issue
Just extended the wiring in my '05 RK Classic and tested it out just now:
I attached the handle bar loosely to the bike and tested the controls. Immediately when I turn on the ignition the left turn signal comes on and the left turn signal button seems to not have any control. Once I press the right turn signal buttons, both turn signals come on and after a few times just the right turn signals comes on and off as it should. All other functions appear to work as far as I could test right now.
Any ideas or suggestions?
Thanks!
Old Nov 1, 2014 | 12:48 AM
TriGeezer's Avatar
TriGeezer
Uh...ya screwed up the turn signal wiring?
Need more information on how you extended the wiring. Without that info start by rechecking your work.
Old Nov 1, 2014 | 07:11 AM
andyshd's Avatar
andyshd
Mmmmmhhhh, well I got a wire extension kit. Took the headlight/nacelle apart to access everything, disconnected the right and left housing wires, took the handlebar off, wrote down the color codes and order of existing wires, disconnected them at the Deutsch connectors, added the extensions, shrink tubed them, reconnected them, assembled new housings, switches, pulled wires internally through the handle bar, reconnected to Deutsch connectors. I did recheck the color codes and couldn't find any issues.
I thought that was the only way to do this?
Old Nov 1, 2014 | 07:42 AM
andyshd's Avatar
andyshd
I took the handlebar back off this morning and double checked the wire colors in the connectors on the handlebar vs the connectors inside the nacelle and everything is in the right order. I guess that means I must have screwed up when I connected the extension to the existing wiring. Before I undo everything: Is there another area that could be the trouble maker?
Old Nov 1, 2014 | 02:55 PM
TriGeezer's Avatar
TriGeezer
Might have caught a burr in the handle bar. Use an ohm meter. Put on lead on the bar, and then touch one end of each wire. If you get continuity, you got a short to the bar,
Old Nov 1, 2014 | 03:31 PM
andyshd's Avatar
andyshd
Can't figure it out. All other controls work as they should.
Any ideas/suggestions?
19jake91
Jan 3, 2018 04:00 AM
TylerBoehm
Feb 13, 2014 06:39 PM
Solly
Jan 27, 2013 01:50 PM
eastcoastink
Jun 26, 2012 08:45 PM
juggernaut2874
May 26, 2010 12:13 AM
