Turn Signal Problems
Old Feb 21, 2015 | 10:02 AM
HD daddy's Avatar
HD daddy
Stage IV
Default Turn Signal Problems
My turn signals front, Rear, Left, Right will only come on solid but will not flash.
The hazards flash just fine. HELP??!!
Old Feb 21, 2015 | 10:29 AM
enodrano's Avatar
enodrano
Did you replace the bulbs or make some other change when this started happening or did it just start happening without any known changes?
The relay for the turn signals could be bad. Also using an 1156 (Single Filament) bulb could cause these issues. Make sure you are using 1157 (Dual Filament) bulbs. Keep in mind too that a 1157 bulb may have one of it's two filaments blown.
Old Feb 21, 2015 | 10:38 AM
HD daddy's Avatar
HD daddy
Stage IV
The bike didn't have rear turn signals on it when I purchased it. I just wired in the new ones. The fronts would not flash before hand ether. Ill check the bulbs hopefully that's it but I'm not that luckey.
Old Feb 21, 2015 | 10:48 AM
enodrano's Avatar
enodrano
An 1156 bulb can act as a running light or flasher but not both at the same time. An 1157 bulb can do both at the same time. Make sure the flasher/relay for the blinkers is good and present. It sounds like the one for the 4-ways works.
Old Feb 24, 2015 | 04:51 PM
okcjetmech's Avatar
okcjetmech
Enodrano is right check your turnsignal flasher, It also is quite helpfull to finish your signature with your bike info that can be helpfull too.
Old Feb 24, 2015 | 05:27 PM
RANGER73's Avatar
RANGER73
We could guess all day, you have to give us more info. Different year bikes have different controls.
WarrenNZ
Electrical/Lighting/Alarm
11
Jun 29, 2022 06:33 AM
Seth64
Oct 15, 2012 09:38 PM
Travlinman314
Mar 9, 2008 12:24 AM
jose409
Feb 18, 2008 11:50 AM
bass2
Mar 15, 2006 02:18 AM
