Stator Plug to Regulator Question
Old Apr 12, 2015 | 09:59 PM
TriGeezer's Avatar
TriGeezer
Default Stator Plug to Regulator Question
I had to relocate the regulator and do done rewiring on my 2012 Ultra Classic Trike to accommodate a Jagg Oil Cooler. And dang now I'm not getting proper/any charging voltage, and the engine & battery light came on. So, I'll be diagnosing what I did wrong.
But, the one question I had, that I could use some help. The connector from the stator (AC side) that plugs into the regulator has 3 pins and wires. It does not seem to be keyed, and therefore I assumed it was not sensitive to how it was oriented. Is my assumption correct?
Thanks...
Old Apr 13, 2015 | 01:52 PM
whyrzwaldo's Avatar
whyrzwaldo
Yes you are correct. The plug has 3 phase AC voltage coming out of it from the stator. You will measure the same AC voltage across any combination of any 2 pins.
Old Apr 13, 2015 | 09:30 PM
TriGeezer's Avatar
TriGeezer
Cool..that's what I thought. Thanks for the good reply!
fujiyama
Shovelhead
47
Sep 21, 2025 11:17 PM
Motorbulldog
Apr 4, 2013 07:27 PM
fastball44
Electrical/Lighting/Alarm
Nov 4, 2010 07:52 AM
fastball44
Oct 10, 2010 08:44 PM
ronn39
Feb 3, 2007 01:51 PM
