Charging System Issue
Old Mar 20, 2016 | 12:33 PM
SkywagonJim's Avatar
SkywagonJim
Stage II
Default Charging System Issue
My 2012 FLHTK will periodically display the Battery lite illuminated, and the Engine lite illuminated at the same time. When this happens, the displayed battery voltage drops from about 14.6 vdc, to about 11.5 vdc. After riding for a few minutes (the amount of time seems to vary from as much as 10 minutes, to as short as a couple of minutes), the lights go out, and the voltage returns to about 14.6 vdc.
I suspect the VR (voltage regulator), but when I took the bike to the Harley dealer the first time that this occurred, while still under warranty, they couldn't find anything wrong. Now, a couple of years later, it is happening again, but now, it happens almost each time that I ride it.
Are there any suggestions from others that have had similar occurrences with their bike? What did you do to correct the problem?
Thanks in advance.
Jim
Old Mar 20, 2016 | 02:32 PM
Ed Ramberger's Avatar
Ed Ramberger
Recall/bulletins on those regulators. Some that were replaced were bad. Very common 2012 touring.
Regulator gets hot, fails. Cools off, works.
Old Mar 22, 2016 | 11:24 AM
SkywagonJim
Stage II
Thanks Ed, I appreciate your response. I will talk to my dealer today about it.
lefty33
Electrical/Lighting/Alarm
Mar 24, 2018 10:41 AM
skinman13
Aug 24, 2014 04:40 PM
128auto
Oct 23, 2013 06:05 PM
Streetrunner
Aug 23, 2009 08:06 AM
06yellowrg
Aug 4, 2007 03:57 PM
