Wiring in a horn (basic wiring question)
I have a 12v with 20a fuse off the battery For a 12v->5v adapter for my phone charger. Fine
If i want to tap off this, and heat shrink it, how would I do this without cutting the wire? I'm trying to reuse the fused lead as its only drawing 3a max and the battery connection is a bit crowded already. I want to solder and heat shrink it as its for the horns and they're kinda useless if unreliable.
I know this is a bit dumb but I'm not seeing how I should do this.
You're probably better off with a Scotchloc tap connector:
http://solutions.3m.com/wps/portal/3...4245698&rt=rud
They're available at auto parts stores.
Otherwise you have to cut and resolder the connection to be able to heat shrink it.
I'll just run a 2nd fused line and keep it all tidy with plastic loom too.
