charging issue ironhead
Old Jul 20, 2016 | 09:56 AM
petarm1's Avatar
petarm1
Stage III
Default charging issue ironhead
good day folks. i have a 1982 FLH iron head 1000 that for some reason will not charge over 12.75 volts, it has a alternator conversion kit with a electronic ignition. went through the trouble shooting flowchart that came with the alternator( A/C multi meter on wires from alternator, 13 volts at idle-18 volts 2000 rpm- 20 volts 3000 rpm) tested the regulator as much as one can test it but decided to buy a new one and installed it. at idle reads 12.6 volts and when revved to 3000 rpm will max at 12.80. i have cleaned the metal where the regulator mounts, attached a separate ground wire, have moved my battery ground to a new location, have replaced the old battery with a Harley Davidson battery. still no change.
i hope someone has the answer that i am obviously missing.
thanks and ride on
petar
98hotrodfatboy
Electrical/Lighting/Alarm
Jun 24, 2019 09:16 AM
Miker7
Nov 22, 2018 06:58 AM
cnnesseth
May 5, 2014 11:18 AM
DR_DEUCE
Nov 6, 2012 04:41 PM
wizardry68
Ironhead
Aug 28, 2009 04:57 PM
