Hey guys jusy fitted a victory headlight to my breakout. It comes with 2 circuits a high beam and a lo beam. Each circuit has a postive and a negative each.
The breakout harness has 4 wires. A negative, a park light, hi and lo. I wired the hi and lo to each individual postive of the headlight. I than spliced both negatives of the lo and hi beam and connecyed to the single negative on the harness. And i left the park light blank.
I now.have no light but the hi beam indicator on the dash works?
What kind of bulb are you using that has a 5 wire pigtail socket? Pull the bulb, check your socket bike side, then jump out what you think the bulb side wires are. Chances are that's where the error is.
