No power to rear right signal
Old Apr 28, 2017 | 03:45 PM
CBCanada's Avatar
CBCanada
Default No power to rear right signal
The bike is a 1996 FatboyThe rear turn signal on the right side has stopped blinkingBulb looks OK I have tested the ground and the ground is OK. There is no power coming to the wire that's attaching to the Bulb it's a purple wire
what should be my next step where should I check is the best method to track back from the lights? if I do that it looks like I'm going to have to remove possibly the rear fender?
thanks
Old Apr 28, 2017 | 04:13 PM
CBCanada's Avatar
CBCanada
I disconnected the harness that seems to be going to the back lights
there is three pins that show power
one of which is a common pin and the other two alternates in showing power when I signal left or right
meaning one is showing constant power regardless of the direction of the signal and the other two pins are alternating with the direction of the signal
from this I am guessing I am getting power up to this point and the problem lies from here back to the signal?
wattlesd
Electrical/Lighting/Alarm
May 1, 2016 03:12 PM
New Adventures
2014-2024 Touring Models
Jun 14, 2015 05:42 PM
Good Time Gang
Nov 11, 2009 07:42 PM
harley2015
Aug 9, 2008 07:03 PM
TxMoores
Feb 13, 2005 12:24 AM
