Starter not working
Old Jun 8, 2017 | 04:36 PM
twistedironshop's Avatar
twistedironshop
Default Starter not working
Good battery, new relay, power to lights and dash, just won't crank. If I jump power from battery to solenoid it cranks. Thought relay bad so I replaced it, still nothing. Fuses all check ok. How do I get to the wire ends for starter switch? Anything else I should check?
Old Jun 9, 2017 | 11:49 AM
twistedironshop
Checking at relay green wire to starter has continuity. R\BK wire hot with ignition on. BK\R wire hot when starter button pushed. TN\GN hot when starter button pushed. I've replaced the relay twice now so I'm guessing its ok. What reason could there possibly be for it not to crank? If I jump battery to solenoid it cranks.
Old Jun 9, 2017 | 01:24 PM
cuda67bnl's Avatar
cuda67bnl
Run switch?
Old Jun 9, 2017 | 03:53 PM
twistedironshop
Originally Posted by cuda67bnl
Run switch?
I believe the power for the start switch, which I have, comes from the run switch. If the run switch was bad I wouldn't have power to the starter button as I read it. If I'm wrong that might be the ticket so if I'm wrong there let me know. I'm no electrician.
Old Jun 9, 2017 | 04:00 PM
cuda67bnl's Avatar
cuda67bnl
If the run switch is off, broke, etc, the starter button doesn't work.....
But you say you have power coming off the start button to the starter, right?
Old Jun 9, 2017 | 04:08 PM
twistedironshop
Then that's not it because I have 12v on the BK\R wire at the relay when the button is pushed correct?
Old Jun 9, 2017 | 04:20 PM
cuda67bnl's Avatar
cuda67bnl
My guess is that the solenoid is bad if you have power going to it when you press the button. You might try checking/cleaning the contacts
Old Jun 9, 2017 | 07:52 PM
twistedironshop
No power to the solenoid. Power stops at relay but I've replaced it twice now. Does anyone know when the TN\GR wire from module to relay is supposed to be hot? Mine is hot when the starter button is pushed.
Old Jun 9, 2017 | 07:53 PM
twistedironshop
I have it to the relay but not to the starter. Replaced relay twice.
Old Jun 9, 2017 | 08:34 PM
cuda67bnl's Avatar
cuda67bnl
Need a schematic...... What year and model?
