intermintant problem
Old Sep 9, 2017 | 07:25 PM
MURPHCC1's Avatar
MURPHCC1
Default intermintant problem
Ok......07 EGUC......43K miles......
this has happened to me twice......once a few months ago........once today
start bike......all gauges are in the good......
After market Biketronics 4180 amp is the only residual draw...all else stock
Driving down the street, see the battery and engine light on, voltage shows about 9 volts.........pulled over and revved the engine up to about 3500RPM........charging kicked right in.......right back up to 14volts, battery and engine lights go off.
Checked the voltage from stator......all good.
Voltage regulator checks good..........
Cables all good and tight with dielectric grease at battery.
Whats dieing on me.....regulator or stator?
Don't want to be left hanging somewhere.......
Thanks
Old Sep 10, 2017 | 07:04 PM
cficole's Avatar
cficole
No codes? Check voltage at bike meter with a known good meter.
EDIT: Oops, just saw you got idiot lights. What are the codes?
Primary oil stink?
I'd kinda lean toward intermittent bad connections or regulator.
Old Sep 11, 2017 | 07:31 AM
MURPHCC1's Avatar
MURPHCC1
code P0562 low voltage.
Voltage at battery is good
Haven't check the stink factor...
Battery checks good at AUTOZONE under load.......
path of least resistance, gonna replace regulator first as replacing the stator is a PIA!
Primary oil stink?
T Man
Jun 12, 2017 02:13 PM
stmcmann
Jun 2, 2016 12:01 PM
mack03
Jul 17, 2015 06:51 AM
TooEasy
Dec 19, 2012 05:19 PM
Knight2
Dec 22, 2009 04:48 PM
