Starting problem
Old Mar 17, 2018 | 11:44 AM
dwg dave's Avatar
dwg dave
Default Starting problem
2000 Softail Deuce with 2004 Motor Trike conversion, Champion reverse gear.
When putting the bike away last fall for winter and backing it up the bike stalled. Tried to restart, bike neutral light was on and I had the clutch pulled in because it still might have been in reverse. As I pressed the start button all the lights on the bike dimmed and the starter did not work. I have no idea what went wrong, a short, bad ground, jammed starter or gears even though I had the clutch pulled in. Hoping for an easy solution as the trike is in the back of my barn in a very tight area and impossible to tow out of where it is. Thank you in advance for any help you may be able to provide.
Old Mar 17, 2018 | 11:58 AM
nevil's Avatar
nevil
Didn't realize you posted in another area, but the battery has to be the first variable you have to look at. You didn't say how old it is or if you keep it on a tender, but it sounds like it's bad. Get it charged up and tested.
Old Mar 17, 2018 | 03:08 PM
dwg dave's Avatar
dwg dave
Battery is two years old this spring, stored inside in winter and is put on a battery tender every month. Always shows slight discharge but enough to start bike.
Old Mar 17, 2018 | 05:11 PM
nevil's Avatar
nevil
A battery tender is meant to be kept on the battery through the winter. A tender and charger are not the same think. If you were putting the battery on a charger every month that's different.
I still think you should get it fully charged and test it. Also make sure the cables at the battery and ground are clean and tight. If that all checks out, then go from there.
Old Mar 23, 2018 | 09:05 AM
dwg dave's Avatar
dwg dave
I got the battery tested and its good.
Old Mar 26, 2018 | 11:30 AM
Max Headflow's Avatar
Max Headflow
Put a voltmeter across the battery terminals and try to start. Voltage should not drop below 9 volts.
c50plus
Milwaukee Eight (M8)
Mar 29, 2019 10:40 AM
dwg dave
Mar 25, 2018 11:18 AM
johntaylorny
Mar 15, 2016 03:10 AM
Jor3lBR
Aug 19, 2008 10:40 AM
johnnychum
Mar 25, 2008 07:16 PM
