Starting problems
Old Mar 17, 2018 | 11:45 AM
dwg dave's Avatar
dwg dave
Default Starting problems
2000 Softail Deuce with 2004 Motor Trike conversion, Champion reverse gear.
When putting the bike away last fall for winter and backing it up the bike stalled. Tried to restart, bike neutral light was on and I had the clutch pulled in because it still might have been in reverse. As I pressed the start button all the lights on the bike dimmed and the starter did not work. I have no idea what went wrong, a short, bad ground, jammed starter or gears even though I had the clutch pulled in. Hoping for an easy solution as the trike is in the back of my barn in a very tight area and impossible to tow out of where it is. Thank you in advance for any help you may be able to provide.
Old Mar 17, 2018 | 11:51 AM
nevil's Avatar
nevil
The battery is always the first place to look. From what you say it sounds like it's bad.
Old Mar 17, 2018 | 03:13 PM
dwg dave's Avatar
dwg dave
Battery is two years old in spring and removed from bike for winter and store in heated area. I put the battery tender on once a month and it shows slight discharge but enough to start the bike.
Old Mar 17, 2018 | 03:29 PM
CoolBreeze3646's Avatar
CoolBreeze3646
If you have the battery out, take it to Walmart or other auto place and have it load tested. Just because it has good charge/volts does not mean it has enough starting amps. Free to check normally, then go from there.
Old Mar 23, 2018 | 09:05 AM
dwg dave's Avatar
dwg dave
I got the battery tested and its good.
Old Mar 23, 2018 | 09:21 AM
jkinner's Avatar
jkinner
Mine tested good at Auto Zone, so I took it to the dealer, their test can take up to 2-3 hours, I didn't make it to the door before they called me back, it was bad. Test was free.
Good luck.
Old Mar 25, 2018 | 11:18 AM
dwg dave's Avatar
dwg dave
I brought it to the Indy who work on my bikes. He put it on a load test and it was fine
dwg dave
Electrical/Lighting/Alarm
Mar 26, 2018 11:30 AM
SpaceCoastHarley
Dec 29, 2014 08:37 AM
toad6301
Oct 13, 2011 09:23 PM
robo5555
Feb 8, 2011 08:42 PM
airollio
May 15, 2007 03:00 PM
