90 softail indicator problems
Old Aug 4, 2018 | 01:44 AM
POP13's Avatar
POP13
Stage II
Default 90 softail indicator problems
Hi guys just seeing if anyone has any advice my blinker stopped working i just replaced the indicator modlue as it a 12 month 90 it has the 91 module in it blinkers now turn on but dont flash however if i put hazards on they do have cheked all bulbs working does it have a flasher unit as well
Old Aug 4, 2018 | 06:20 AM
grbrown's Avatar
grbrown
Interesting! The unit used on 1991 Softails seems to be: 68537-89G, TURN SIGNAL CANCELLER, which suggests there is also a flasher unit. However my 1990 Glide, bought new, has the same module which controls all aspects of the flashers, including hazards. The MoCo does use some odd names! My unit flashes left or right indicator lights, plus all four of them, also turns them off after a set time or distance travelled. So no, it doesn't also have a flasher unit.
I suggest you remove and clean each bulb, to confirm the holder is clean and rust/crud free, so your bulbs have a nice clean place to call home! Old bulbs can get up to a few tricks, so if any of them look dirty inside the glass replace them. Also check connectors and grounds, as sometimes electrical problems can be down to simple things. Best of luck!
jpbutler1983
Mar 29, 2021 12:00 AM
Brazeal
Electrical/Lighting/Alarm
Apr 23, 2015 11:59 AM
pmedic433
Sep 10, 2012 12:36 AM
Night Hog
Feb 11, 2010 10:38 AM
guild
General Topics/Tech Tips
May 22, 2007 03:07 PM
