Changing Speedometer Wiring Problems
I changed the original Speedometer of my Dynaglide FXDI (2005) to a free-style part. I succeeded in redirecting most of the signals to new LED (Ignition, Oil Pressure, Turnlights, Alarm etc). But I failed in case of the warning-signal for the fuel-level, which was a red signal in the speedometer. Probably the correct wire is a yellow-white-signed. I find this wire, but by connecting it to the external LED I get permanent lights, even if the fuel level is high. Did I choose the wrong wire or am I failing because of another reason?
Greetings from Germany
Redrobber
