smart siren wont sound
Hello, everyone. Just installed a smart siren in a 2017 sporster xl1200x and tried to get it to sound? also tried chirp enable in configuration via the ignition switch toggling as per H/D Sip portal info. if it was in silent mode to no avail? Any help with this would be much appreciated .
Hello, fob near bike or away and flashers flash in alarm , but no siren or chirp when not in alarm ? installed a second siren same thing. Dealership says bring it in. Im thinking its just locate the plug , plug it in? Its gotta be flashing the BCM, ECM module via ignition switch toggling, and or four way hazard switch toggling? Can;t find anything in SIP portal, but I dont have service manual for it either. 12 VDC on outter two terminals of the siren but center post is the signal from the BCM module and dont know if thats part of the can-bus control logic and not surre what this voltage is other than being PWM
