Radiantz smoke lens LED tail light, Road King run/turn/brake light bar with Custom Dynamics LEDs and smoke lenses, Custom Dynamics fender tip lights under smoke lenses. I am using the CD run/brake/burn strobe module. I am waiting for parts to put the front back together but I am using Daymaker LEDs with Custom Dynamics amber turn LEDs with smoke lenses.
I was not on center with this shot causing the right light looks dimer than the rest. The fender tip LED is also much brighter when viewed from a following car
As for headlights, I was hell bent on either a Hogworkz or Day Maker. Then I decided to waste $50 on an amazon special. It's DOT approved, been on the bike for 18 months, works fantastic, and if/when it dies....it was only $50. I recommend taking a look. You can even get the 4" lights. Good luck.
Hey Zephis, we have a number of LED lights that will fit your bike, including the turn signals, passing lamps, and headlamp. Because you've got a '93, you don't have the convenient HD connectors that the later models do, but if you want to give us a call at 800-382-1388, we'd be glad to help you work out which parts you need.
I got the Hogworkz. Lots of good reviews. They came in today will install them tomorrow and see how they are. My only option with custom dynamics was their gen 1 and i didn't like that one. Their others create to much interference on MY BIKE. This was from the customer rep guy at Custom Dynmaics. I am assuming because I have an older bike. I would like to try their tail light but I am not so sure.
