Brightness changing
Old Jul 24, 2019 | 10:46 AM
tafdeluxe's Avatar
tafdeluxe
Default Brightness changing
When night riding I notice my lights changing brightness. Not long ago, my battery light came on, once very briefly, then a few days later, for about a minute. Checked battery voltage not running and running; 12 volts and change and 13 volts and change. My Indy says swap out my Drag Specialties battery for HD and he also thought when running the voltage was low. Last night my dash lights were intermittently going out. I don't think swapping out what tests as a fine battery is the answer. Thoughts? My post is maybe too early as I have yet to go through connections. Just hoping someone has had the same experience. Checked battery for loose terminals and they were fine. Terminals had no corrosion but were not pristine. Will be doing that today but I can't see that being the trouble. Starts like a champ. When I lost the dash lights the bike kept running without issue. Thanks for all replies.
Old Jul 24, 2019 | 04:29 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
How old is the battery?
Old Jul 24, 2019 | 05:54 PM
tafdeluxe's Avatar
tafdeluxe
I forget but at least three years. Now that I have written that it makes consider replacing, however it has been on a tender through the winter and any lengthy no use time. What are the thoughts on after market batteries vs HD? I have been satisfied with this drag specialties and another I had purchased for my previous bike.
Old Jul 26, 2019 | 09:35 AM
skinman13's Avatar
skinman13
At least 80% of the questions relating to charging system issues have a common factor of old or aftermarket batteries...a point to consider when deciding on a new battery. The MoCo battery may not be the only one for your ride, but it will always be the best choice in my experience.
Old Jul 28, 2019 | 09:30 AM
tafdeluxe's Avatar
tafdeluxe
Well bit the bullet and paid the near $200 for the HD battery and still have the changing brightness issue. Have not lost my dash lights since cleaning up terminals. Battery salesman spoke of a voltage regulator. Looking on YouTube for r and r procedure.
Old Jul 28, 2019 | 11:09 PM
Max Headflow's Avatar
Max Headflow
If connections are good, I would say your alternator or regulator is going bad.
Old Jul 29, 2019 | 04:33 PM
tafdeluxe's Avatar
tafdeluxe
Next is the regulator. And hopefully it ends there for now.
Old Jul 29, 2019 | 08:39 PM
RANGER73's Avatar
RANGER73
Trace the battery leads and check all the connections as well as the cables themselves.
The copper strands rot under the insulation, especially if you live near the coast or wash the bike often.
Old Jul 29, 2019 | 09:33 PM
bustert's Avatar
bustert
how much load are you running on the system???
the system will run off the pmg and the battery will provide short fall. you must allow 20% of charge capacity to assure battery charge. if the regulator is iffy, you will see the lighting go down when the battery is supplying the short fall. of importance is the connections at the regulator especially the ground, some add a ground jumper.
when mine started acting up, it eventually wound up being the pmg winding to regulator pigtail connection, was a bear to find at first since it was sporatic.
Attachment 617778
Old Aug 25, 2019 | 12:37 AM
tafdeluxe's Avatar
tafdeluxe
Well I swapped out my headlight and my passing lamps with LEDs. Several night trips without brightness changing. However my dash red light on on the way home tonight.
