Help
Old Aug 11, 2019 | 03:29 PM
Goose1950's Avatar
Goose1950
3rd Gear
Default Help
2014 heritage softail I was riding and the battery light come on almost didn't make it home before it died put it on a charger now when it gets hot the battery light comes back on
Old Aug 13, 2019 | 10:57 AM
grbrown's Avatar
grbrown
At the top of this Electrical section you will find two Stickies telling you how to check your charging system. They should help identify if you have a charging problem and what is causing it. Otherwise I suggest you find a local indy and visit him, as it should only take a short while to identify what is causing your problem.
Old Aug 19, 2019 | 08:26 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Charge the battery, take it to a shop and have it load tested.
Clean all battery connections.
Perform charging system check.
Old Aug 21, 2019 | 06:19 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I know that 2012 and 2013 voltage regulators had issues of just crapping out. Did you check for codes? and I would suggest getting a factory service manual it'll guide you through the complete procedure... Did a job on a friend's 2013 road King believe the code was PO562.
Old Aug 22, 2019 | 04:06 PM
Goose1950's Avatar
Goose1950
3rd Gear
Default Help
How do I check for codes put new battery new regulator on it and the voltage won't go up the battery is at 12.5 drops when I start it jumps back up
Old Aug 23, 2019 | 08:48 AM
98hotrodfatboy
You posted this on 8/11 in another thread... Did you get a service manual as suggested in that thread?... Cause your gonna need it... It's all in there.....
Goose1950
Aug 11, 2019 05:31 PM
sanman4ever
Mar 10, 2016 04:40 PM
slack
Aug 12, 2008 09:26 PM
alemke
May 26, 2008 10:44 PM
melrose68
Jul 1, 2007 09:57 AM
