Help
Old Aug 11, 2019 | 11:07 AM
Goose1950's Avatar
Goose1950
3rd Gear
Default Help
Ok I have a 2014 heritage softail battery light come on almost didn't make it home before it died .put the battery on charge now it comes on after the bike gets hot does that sound like a bad battery
Old Aug 11, 2019 | 11:09 AM
FlamedFXR's Avatar
FlamedFXR
Check for stored codes and have the battery load tested.
Old Aug 11, 2019 | 11:15 AM
Goose1950's Avatar
Goose1950
3rd Gear
Default Help
The battery light will go off after the engine cools off I'm new at this trying to figure it out
Old Aug 11, 2019 | 11:54 AM
WP50's Avatar
WP50
Have you got a service manual? I know more about older ones but the symptom you have kinda points to a voltage regulator.
Not saying it is a regulator but some testing is in order.
As mentioned see if there are codes set and do a load test on the battery.
WP
Old Aug 11, 2019 | 12:41 PM
Goose1950's Avatar
Goose1950
3rd Gear
Default Help
Ok thanks but will a regulator just go out
Old Aug 11, 2019 | 01:27 PM
WP50's Avatar
WP50
Yes they can as well a battery also.
The battery is a possibility just not as likely in what you have described.
I might suggest you post this in a part of the forum more related to the problem.
https://www.hdforums.com/forum/elect...ting-alarm-43/
Old Aug 11, 2019 | 05:31 PM
sechracer's Avatar
sechracer
Do not rule out the stator. Pull the derby cover and give a whiff. If its bad, you will know.
cgmartine
Electrical/Lighting/Alarm
19
Nov 11, 2020 10:56 PM
sandrooney
2018+ Softail Models
26
Jun 11, 2019 11:52 AM
lol_paul_ledoux
General Topics/Tech Tips
Apr 15, 2015 11:00 AM
jlfabian
Sep 21, 2012 09:46 AM
dirtydawg1
May 9, 2012 04:58 PM
