Help!!!
Old Aug 27, 2019 | 10:42 PM
Guzman.david2013@yahoo.com's Avatar
Stage III
Default Help!!!
Got codes b2161, b2272, u0141. Brake light stays on. Front and rear brake does not make a difference. Already checked the bulb and front and rear brake switch. 2011 Softail Deluxe. If its not the switches, what else could it be? Thanks in advance.
Old Aug 28, 2019 | 05:57 AM
enodrano's Avatar
enodrano
The following 2 codes will be present when the break switch is open:
B2161 = Brake lamp output open
B2272 = BCM/IM voltage high
This code can mean many different things, but in this case it likely means "Break Switch Stuck Open"
U0141 = Lost comm w/LHCM
Check the plunger on the brake fluid reservoirs. The gaskets often dry out and will prevent the plunger from returning far enough to close the switch and turn off the brake light. You can lubricate the plunger and gasket with brake fluid. This happens to me a lot on my 2011 Street Bob. You will have to loosen the controls on the handlebar to get to the front brake plunger. Also, have a rag handy so you do not get brake fluid on any painted surfaces.
If code U0141 does not go away after you get the break switch to close you may have another issue to solve. Code U0141 can also be a false/positive if you're using a piggyback (non-flash) tuner like the Vance and Hines FuelPak.
Good Luck!
JonnyVegas
May 29, 2019 08:01 AM
dpiccman@msn.com
Aug 19, 2018 11:35 AM
Shepherdboy44
Aug 16, 2018 03:28 PM
poncho1953
May 20, 2015 08:47 AM
BlackFLHR
May 24, 2011 02:01 PM
